SketchUcation Plugin Store
Newbie Tutorial - How to close any face in Sketchup
Postby EarthMover » Fri Sep 04, 2009 1:50 am
This is a really brief tutorial to show a progression of steps that will allow you to trouble shoot why a face won't close and a guaranteed solution to close any face.
In teaching different people Sketchup, closing faces is one of the most frustrating things for some people...especially in the learning phase. Hopefully this simple troubleshooting method will help alleviate some headaches for new users.
Requires several plugins. If you have trouble finding them, let me know and I'll post the links.
http://www.screencast.com/users/EarthMo ... f0eed948c5
A designer is an emerging synthesis of artist, inventor, mechanic, objective economist and evolutionary strategist. - R. Buckminster Fuller
Some of my 3D crap
EarthMover
Top SketchUcator
Re: Newbie Tutorial - How to close any face in Sketchup
Postby d12dozr » Fri Sep 04, 2009 3:34 am
Good tut, Adam! :thumb:
"There is a man in the world who will never be turned down... he is the man who delivers the goods."
d12dozr
Top SketchUcator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: product design
Level of SketchUp: Advanced
Postby xrok1 » Fri Sep 04, 2009 4:44 am
you forgot freedo scale. scale to 0 in the z axis to make edges coplanar ;)
“There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
xrok1
Postby EarthMover » Fri Sep 04, 2009 12:53 pm
Thanks Xrok1! Good suggestion....I never thought of that! :thumb:
Some of my 3D crap
EarthMover
Top SketchUcator
Postby Gaieus » Fri Sep 04, 2009 1:03 pm
Cool video indeed. We all know that sometimes tracking down some tiny modelling glitches to find out why a particular face doesn't want to create is a PITA.
The projection tools you used last can also be "supplemented" by the Drape tool.
Administrator
SketchUp version: 8
License type: Pro
SketchUp use: historical reconstruction
Postby EarthMover » Fri Sep 04, 2009 2:13 pm
Thanks Csaba :thumb: ...that's another good one. The drape tool is actually easier and quicker I think. I never thought of the drape tool to drape upward, but it indeed works well. The other difference of using the drape tool vs. using the projection plugin is that the drape tool will project the edges into a grouped face and put them inside the group. The projection plugin puts the edges onto the outside of the group. Drape tool will make the edges automatically into a face and the projection plugin has to be done manually by redrawing a line or running Make Faces 1.1. Man, I learn something new everyday!!
Xrok1 - I tried some experimenting with using the Fredoscale to make all edges co-planar, but had no luck. I used the scale to target, clicked on the Z handle, hit tab and tried to enter 0, but it doesn't seem to allow a zero input. Is there another way to work that?
Some of my 3D crap
EarthMover
Top SketchUcator
Postby MercurialArts » Sat Sep 05, 2009 10:43 pm
Why yes, this is frustrating! So, I am an artist making images in photoshop, using magic tracer 2.0 to convert from raster to dxf. Once I import into SU, I can't get a face on the outline, which seems to act as a component. The end result of this process would be dxf files a water jetter or laser cutter could use to cut metal and glass shapes, and the SU drawing being my working drawings. Stray lines finds nothing. But I still can't fill or extrude this shape. Where do I get the projection tools? I tried drape, it only takes the outline, and I have internal stuff as well. I have watched the video several times.... I don't have the bucks to buy more plugins, the software I have cost me my flex funding..
MercurialArts
Postby urgen » Sat Sep 05, 2009 11:46 pm
....and WELD ;)
weld.rar
....and very simple-SUNDBOX+SKIN :lol:
sundbox.rar
--pupil forever...------
urgen
Postby MercurialArts » Sun Sep 06, 2009 1:30 am
So, when I try weld, its says pick at least 2 edges, when I try the sandbox contour method, it says I must choose contours. When I select even one line of my imported dxf the whole thing is selected with a box around it. Every line is blue. What does this mean? It would seem that all the lines are connected... but again, not a solid, no extrusion... Wha?
MercurialArts
Postby MercurialArts » Sun Sep 06, 2009 2:26 am
Ah, what a dork, yes, its a component, edit component, check for stray lines brought up 13 items, I am solid and extruded. Thanks for the tips, I just needed to figure out how to apply all those neeto tricks to my object! dxf gets imported as a component.
I had to
select component,
edit menu, component, edit component
then go through and use stray line tool and weld tool to fix it up. Tiny little problems that are super hard to see, but between repeated uses of both tools, wazambo!
MercurialArts
Postby Gaieus » Sun Sep 06, 2009 11:03 am
You can also edit a component/group from the context ("right click") menu - or even better; just double click on it. If you triple click, you will end up "inside" its editing context PLUS all the geometry inside selected already.
Administrator
SketchUp version: 8
License type: Pro
Postby broomstick » Tue Sep 08, 2009 12:11 pm
awesome video, man. You taught me something i did' nt know about stray lines, and you introduced me to projection tools :)
My I have your permission to do a similar video for my blog in Italian?
broomstick
Postby EarthMover » Tue Sep 08, 2009 3:35 pm
No problem Broomstick! Glad it was helpful. Feel free to use it as you wish.
Here is also a quick follow up video on Closing a face with the Drape Tool.
http://www.screencast.com/users/EarthMo ... 0632e204b7
Some of my 3D crap
EarthMover
Top SketchUcator
Postby broomstick » Thu Sep 10, 2009 9:30 pm
thanks you are very kind. I'll aknowledge you in the video, and post the link as soon as it is up :)
broomstick
Postby mpkarch » Tue Nov 24, 2009 9:14 pm
Earthmover,
I am curious to know where you got all the icons in your tutorial.
MPKArch
mpkarch
Postby brookefox » Sun Apr 29, 2012 11:36 pm
I posted a link to this, Adam, and send along my thanks as well. Duh... 'stray lines' was sitting lonely in my PI folder unnoticed and forgotten by me...
~ Brooke
brookefox
SketchUp version: 8
License type: Free
SketchUp use: architecture
Postby EarthMover » Mon Apr 30, 2012 2:35 am
No problem. Some new plugins have been released since this tutorial that change the technique a bit.
Particularly "Edge Tools" from ThomThom - viewtopic.php?t=24593 has the feature Close Gaps. This is much easier than "label stray lines" as it does the work of solving the gaps as well.
Also another one I find helpful with a stubborn face is "Flatten & Extrude" from ThomThom. -http://forums.sketchucation.com/viewtopic.php?t=23491. Once the gaps are closed you can group the edges and run the Flatten script and it will move all the verts to the same Z and close all the faces. (TIG's "Drop Verticies" will do similar on ungrouped edges but will not close the face automatically - viewtopic.php?t=39251)
Hope this helps.
Some of my 3D crap
EarthMover
Top SketchUcator
Postby brookefox » Mon Apr 30, 2012 2:54 am
Great... but given the omnipresence of the issue your tut is good enough to warrant updating and sticking somewhere! (G man :geek:)
~ Brooke
brookefox
SketchUp version: 8
License type: Free
Postby pisosse » Sun Jun 17, 2012 11:31 am
brookefox wrote:Great... but given the omnipresence of the issue your tut is good enough to warrant updating and sticking somewhere! (G man :geek:)
CONCUR...!
pisosse
Postby ScrubBrush » Wed Aug 22, 2012 6:19 am
xrok1 wrote:you forgot freedo scale. scale to 0 in the z axis to make edges coplanar ;)
I know this is way behind the curve, but could someone put this into english for us nubs?
ScrubBrush
Postby Gaieus » Wed Aug 22, 2012 9:14 am
Fredo scale is a plugin (a very complex and powerful one actually) that takes a lot of SketchUp's native tools to a next level.
I have been reading (and approving) your posts this morning as I got up and suggest to "learn how to walk before you start running" though but of course, learning how to install and use plugins should also be in your "curriculum".
In short, here is Fredo scale: viewtopic.php?t=17948
And what xrok meant here is that you can scale any loop of edges that is not co-planar to "Zero" which makes it co-planar then.
Here are some screenshots.
Administrator
SketchUp version: 8
License type: Pro
Postby mitcorb » Wed Aug 22, 2012 12:42 pm
And this is a DUH moment for me regarding the scale to zero trick.
mitcorb
Top SketchUcator
SketchUp version: 8
License type: Free
Postby Gaieus » Wed Aug 22, 2012 3:42 pm
It was for me, too. Just checked it out after the question made me curious. ;)
Administrator
SketchUp version: 8
License type: Pro
Postby ScrubBrush » Wed Aug 22, 2012 5:38 pm
that cleared it up for me too. and looks useful, I'll add that one to my plugins.
I'm past the walk stage for the most part. just can't get past the jogging stage.
ScrubBrush
Artisan Organic Toolset - a set of powerful organic modeling tools.
Return to SketchUp Tutorials
Users browsing this forum: regnitiab and 7 guests
