Adjust a dark photo?
Postby Joe Wood » Sat Feb 24, 2018 10:14 pm
I'm scanning some old pre 1990 project photos and they're coming out a bit darkish. I just barely use Corel Paint and Draw, don't know much about manipulating images like this. I played with the brightness though and got some nice results :-)
what else could I do to improve this image?
BTW This house was built here in San Diego for the Chinese ambassador in the early 30s!
I did the roofed entry and fencing work. Twice I was turned down when I asked the owner if he'd let me go up in to the attic. I wanted to see how that roof was framed!! I wish I had been more persistent!
here's the original, the gate is just a black rectangle. In the one above I can just see the vertical batts on the double gates.
Joe Wood
Re: Adjust a dark photo?
Postby Mike Amos » Sun Feb 25, 2018 12:02 pm
I think being too persistent may cause a bigger problem in the long run. I would be looking for local planning body files, there should be decently detailed prints for the area's you want to see.
https://www.sandiegohistory.org/library_programs/
Premium Member
Premium Member
Postby Joe Wood » Sun Feb 25, 2018 2:31 pm
I doubt there were any photos taken during this time, if I understand your answer Mike, besides I want to understand how to adjust dark photos like this.
Joe Wood
Postby pbacot » Sun Feb 25, 2018 6:14 pm
My experience the local planning / building departments barely have records, let alone drawings prior to the last couple decades. Somehow, asking for multiple copies, they lose or destroy them all or never put them on film. Now they will likely get scanned and put on an antiquated computer network. The departments barely existed in the early 20th century.
MacOSX Mojave ShetchUp Pro v19 Twilight Pro v2 M2 Kerkythea PowerCADD
Top SketchUcator
Postby Joe Wood » Sun Feb 25, 2018 6:28 pm
Plus I took this photo around 1991.
So how else can I improve these photos besides the brightness, contrast and intensity?
Joe Wood
Postby tuna1957 » Sun Feb 25, 2018 8:30 pm
Joe, If I understand correct , your wanting to "brighten up" the area of the gate. If that's the case your starting to cross into some more advanced territory with an image editor. I'm by far no master at this but I took your pic into Gimp to see what I could do. Biggest roadblock for me is not knowing what the gate actually looks like. Reposting the pic to show where I ended up. Will try and describe what I did....
First I cropped the white border off the top of the image. Ran the "Auto White Balance" tool. Used the "Curves" tool to brighten up the image. I have found the "Curves" tool doesn't screw the colors of image up as bad when trying to brighten up dark images as much as using "Brightness & Contrast" does.
Now the fun begins. Used the "Select by Color" tool to select the area of the gate. The "Curves" tool brightened this area up but the colors got pretty whacked out. Had to use "Color Balance" and "Hue & Saturation" tools along with the "Scissors Select" tool to try and work the color back where I thought it looked o.k. When I got the gate looking reasonably decent did minor "Hue & Saturation", "Brightness & Contrast" on the whole image and there you have it. Hope this long winded example helps some.
tuna1957
Premium Member
Premium Member
Postby Bryan K » Tue Feb 27, 2018 6:41 am
This is the best I could, There simply isn't enough light to work with.
Postby Mike Amos » Tue Feb 27, 2018 12:17 pm
Understood but by my thinking, the roof framing should be in the planning permission papers.
Premium Member
Premium Member
Postby Joe Wood » Tue Feb 27, 2018 5:52 pm
Thanks for going to all the work for me Tuna but I don't use Gimp so don't understand hardly any of those commands you mentioned. The photo came out pretty well though! I was wanting to not just lighten up the gate but the whole image.
Can you explain what you did Bryan, and what program you used? Yours came out pretty well too!
Mike I understand what you meant now, that's a good point about the planning Dept!
Joe Wood
Postby Joe Wood » Wed Feb 28, 2018 1:23 am
This is another original scan I made, you can see how dark it is.
and then me just playing with the Brightness and Contrast a little, and pushing up the Intensity this time, did I set those three Settings well?
and I'm pretty happy with it :-) and it was easy 1 step.
Bryan's looks a little better, so when I'm looking at the Tools in that Adjust menu, if I had to choose 1 more Tool to use would it be Hue / Saturation?
Joe Wood
Postby Bryan K » Thu Mar 01, 2018 1:27 am
I used an old verison of Adobe Fireworks. It has much of the same adjustments as Adobe Photoshop of that era.
I did several things:
The curves (just used auto adjust)
The brightness contrast
Hue adjustment. There was too much red in the picture
Sharpen (yep, sharpen)
Then ran the above again.
So basically, just minimal Photoshop tweaks.
Postby Joe Wood » Thu Mar 01, 2018 1:55 am
Hhmmm, Hue and Sharpen. I'll play with those!
what are these 'curves' Bryan, can you explain?
Joe Wood
Postby Bryan K » Thu Mar 01, 2018 6:34 am
Tone curve. Looks like curvy line inside a a box. You can actually grab the line itself and drag it diagonally. Usually up and to the left. Not very far either.
Postby Bryan K » Thu Mar 01, 2018 6:37 am
Update
Postby tuna1957 » Thu Mar 01, 2018 7:05 pm
Joe, Going to throw one more thing your way.... What resolution are you scanning your originals at ? Higher resolution scans give way more information for the software to work with when doing edits/fixes. The fixed image can always be scaled down if needed for posting on the web.
tuna1957
Premium Member
Premium Member
Postby Joe Wood » Thu Mar 01, 2018 7:46 pm
I was going to ask about the initial scanning.
I put a 4x6" photo on the scanner and scan at a high setting.
the image plus scanner table area scans at 6800x8800
then when I crop the image it's 4600 pixels wide.
Joe Wood
Postby tuna1957 » Thu Mar 01, 2018 8:00 pm
Joe , You can adjust your scanner so it only scans the image. Saves having to go back in and crop out the dead space.
tuna1957
Premium Member
Premium Member
Postby Joe Wood » Thu Mar 01, 2018 8:23 pm
Just discovered the Professional Mode, and see some more settings but nowhere to scan only the image?
Joe Wood
Postby tuna1957 » Thu Mar 01, 2018 10:01 pm
Joe, Took a few minutes... had to unpack the Epson scanner. Haven't used it since packing up from the museum job I was on. You make your adjustments in the preview window. Attached screenshot, hope it helps.
tuna1957
Premium Member
Premium Member
Postby andybot » Fri Mar 02, 2018 3:54 pm
Definitely use "curves" adjustment. Brightness/ contrast is an older mode and gives you much less control. I would highly recommend Lightroom. It's non-destructive and has a really great set of controls for color adjustments. When you scan - set the bit depth as high as the scanner will let you - that will give your image editing program more information to work with.
my blog featuring recent projects
andybot
Premium Member
Premium Member
Return to Corner Bar
