Animating retractable lightsaber
General discussion related to SketchUp Pro and Make
Postby matsuo_lano » Sat Oct 17, 2020 10:30 am
Like the topic said, I want to try and achieve this (I hope rather simple) animation. The idea is to render it with SUPodium when finished. Since this uses scenes for rendering, I found out that Fredo6's animation plugin wouldn't be the right one. Any other plugins I can use?
You try to rearrange me 'till I'm sane
matsuo_lano
Re: Animating retractable lightsaber
Postby Mike Amos » Sat Oct 17, 2020 12:01 pm
How about sketchup scenes? Different lengths of 'blade' on different layers, switch off all but the one you want for each 'frame'.
Premium Member
Premium Member
Postby pbacot » Sun Oct 18, 2020 1:30 am
Could one use the section animation for this. Two scenes with different section cuts. Wouldn't SU animate the transition?
Top SketchUcator
Postby solo » Sun Oct 18, 2020 1:51 am
Technically, a lightsaber beam is about 3ft so from off to fully extended it would take 3.0501e-9 or 10 to the 9 nanoseconds. An animation is what 30 frames per second? so it would take way less than a single frame to extend, no need for animation, render it off then on, there is no visible transition. :puke: :mrgreen:
http://www.solos-art.com
solo
Global Moderator
Postby matsuo_lano » Tue Oct 27, 2020 7:09 pm
Well, I've decided to ditch animating it all together and just make a simple render. Will post it in a few!
matsuo_lano
Return to SketchUp Pro & Make Discussions
Users browsing this forum: Majestic-12 Bot and 6 guests
