Making a solid from a Curviloft form
General discussion related to SketchUp Pro and Make
Postby GonRod » Wed Aug 21, 2019 9:58 pm
Hello From México
You know if there are some restrictions to make solid pieces if you use Curviloft?
I need to Slice my model to cut it on the CNC cutter, but to do that I need a Solid piece, that I made with Curviloft, I checked with Solid Inspector2 and it points me in the lines that has been made with Curviloft. Can you help me please
Thank you
GonRod
Re: Making a solid from a Curviloft form
Postby pilou » Wed Aug 21, 2019 11:23 pm
Select All : Explode your Object
Then Group it
= your have a Group "Solid"! ;)
Speedy Galerie
Top SketchUcator
Postby GonRod » Thu Aug 22, 2019 1:45 am
It work´s perfect!!!
Thank you, can you explain me please how this happens?
GonRod
Postby Box » Thu Aug 22, 2019 4:14 am
When you use Curviloft to make a surface it automatically makes it a group.
So your "solid" isn't because it is made up of several faces and edges of raw geometry and two groups created by Curviloft within the other group. By exploding those two groups you get all raw geometry within one group which is a Solid. You should also reverse the blue faces so you only see white from the outside. Blue faces are back faces.
Return to SketchUp Pro & Make Discussions
