intersect function
General discussion related to SketchUp Pro and Make
intersect function
Postby Leggy » Wed Jul 03, 2019 7:33 pm
hi Ive working on a design see attachment
the square plate is flat, when you pull the circle through the plate and intersect with selected the top face distorts
any ideas?
Leggy
Re: intersect function
Postby TIG » Wed Jul 03, 2019 8:30 pm
The file you attached is the backup file ["step test 15.6~.skp"]
Note that on a PC it'd be named "step test 15.6.skb"
That said, and assuming that the SKP's contents are much like the main model...
There are some critical areas that need fixing.
Try thomthom's SolidInspector² to see them...
It is a relatively simple form that can be made from scratch quite easily, but in its current 'mangled' state it'll be quite hard to 'fix'...
Global Moderator
Postby Leggy » Thu Jul 04, 2019 8:30 pm
sorry try again
Leggy
Postby Leggy » Thu Jul 04, 2019 8:32 pm
sorry correct one
Leggy
Postby TIG » Thu Jul 04, 2019 9:03 pm
That's the backup of a backup file ! ending in "~~.skp"
Don't you have a file named "step test 15.6.skp" ??
With not ending ~ characters - which show it's a backup file ?
If you have worked on the backup file you should rename the file without the ~ otherwise it's the route to confusion......
Global Moderator
Postby Leggy » Fri Jul 05, 2019 1:02 pm
try again
Leggy
Postby Leggy » Fri Jul 05, 2019 1:05 pm
morning
how can you tell what's mangled :o , I keep getting messages that something is wrong , but can never see why
thanks
Leggy
Postby Dave R » Fri Jul 05, 2019 1:27 pm
There's a lot of bad geometry created by the intersection of the two shapes and you need to clean it up. Some of it Solid Solver or Solid Inspector will do but a lot of it will need to be done manually.
Hiding outer surfaces will make it easier to get inside and erase the unneeded stuff.
When you get it all unmangled, it should look like this.
Much of the problem comes from the size you are working at. If you'd taken the advice given in your other thread about working at a larger scale, you would have an easier time of it.
Global Moderator
Postby TIG » Fri Jul 05, 2019 2:22 pm
As Dave says...
It's not a solid because it has lots of modeling errors.
SolidInspector² shows you have many internal partitions and missing faces - both of which prevent solidity - every edge must support two faces - no more, no less.
There are also a lot of leftover faces and edges within the form [especially near the part with the hole].
Your form's size also gets very near the 1/1000" tolerance limit - especially where the curved upstand's segmentation doesn't match the part around the hole and the 'valley' between them is therefore not evenly formed.
Modeling with softened/hidden edges also makes life difficult to see what you are doing.
In the attached SKP [v2017] I've fixed the issues and it's now reporting as a solid.
Note how I've tweaked the Style to shown end-points and profiles, so the repairs are then easier to see.
To get inside I used section-cuts [fill off in Style].
I also un-smoothed all edges, and selected all to use 'unhide', so I could see everything as I went through erasing unwanted geometry.
Global Moderator
Postby pbacot » Fri Jul 05, 2019 6:28 pm
You guys have a lot of patience and generosity...
4
MacOSX Mojave ShetchUp Pro v19 Twilight Pro v2 M2 Kerkythea PowerCADD
Top SketchUcator
Postby Leggy » Sat Jul 06, 2019 2:23 pm
you guys certainly do , Thanks so much for your help
I did scale it up by x10 but obviously wasn't enough
ill download the extensions next week
Thanks again Dean
Leggy
Postby Leggy » Sat Jul 06, 2019 2:27 pm
so is that view on x-ray?
Leggy
Postby Dave R » Sat Jul 06, 2019 3:38 pm
Leggy wrote:I did scale it up by x10 but obviously wasn't enough
As I wrote the other day in your other thread:
you should model in meters instead of millimeters.
That's effectively scaling up by a factor of 1000! I don't know why people are so afraid to scale the model up sufficiently.
Leggy wrote:so is that view on x-ray?
Yes.
Global Moderator
Postby Leggy » Sun Jul 07, 2019 2:41 pm
I see now its in solid inspector, I've downloaded
thanks again Dean
Leggy
Return to SketchUp Pro & Make Discussions
Users browsing this forum: No registered users and 7 guests
