Number of Circle segments
General discussion related to SketchUp Pro and Make
Postby pbacot » Thu May 09, 2019 10:08 pm
I get a warning quite often when I change the number of segments in a circle. I type in something like 96 and I get the warning about the range. Sometimes the edit just works, other times I have to redo. I am in the range so I wonder if there is something I am missing.
MacOSX Mojave ShetchUp Pro v19 Twilight Pro v2 M2 Kerkythea PowerCADD
Top SketchUcator
Re: Number of Circle segments
Postby Dave R » Fri May 10, 2019 2:57 am
That's odd. Where are you changing this value? In Entity Info?
Global Moderator
Postby Mike Amos » Fri May 10, 2019 8:52 am
This can sometimes occur due to input error either adding or removing digits.
Premium Member
Premium Member
Postby pbacot » Fri May 10, 2019 5:07 pm
Yes, Mike but it happens in this case a lot and I am pretry goood at typoiing otherwise.
I usually do it in the entity window, and since I get this message often I look at what I am typing. And this has happened to me in different versions of SU.
It's possible typing "s" afterward helps some of the time.
Top SketchUcator
Postby Dave R » Fri May 10, 2019 5:20 pm
pbacot wrote:Yes, Mike but it happens in this case a lot and I am pretry goood at typoiing otherwise.
Sorry. That made me laugh.
pbacot wrote:It's possible typing "s" afterward helps some of the time.
"s" shouldn't be necessary in Entity Info. It used to be required if you were making the adjustment before drawing a circle but it isn't anymore.
When you are changing the setting in Entity Info, are you selecting the existing number and then just overtyping? Or are you selecting the existing value and deleting it before typing the new number?
Global Moderator
Return to SketchUp Pro & Make Discussions
Users browsing this forum: helmihairizulk and 8 guests
