Every tool stuck on 1434mm inference.
Hi everyone,
Working on Sketchup 2019 MacOs last version, I have an issue with almost every tool I use (line, square, circle, Push/Pull, etc...) : The inference function always stops at 1434mm and every multiple of it 2868,4302,...
Edit/SOLVED : I went to Window/Model info to change from mm to inches just to see what happens and I found the "Enable lenght snapping" ticked with 1434mm value.
Happy to find it by myself, I post it anyway, someone can maybe consider it useful.Happy modeling at all!
TAGS : lenght locked, inference bloquée, blocage, verrouillage, contrainte longueur
Nicely caught, thanks for the heads up.
