SketchUp 2019 CAD file import failure
General discussion related to SketchUp Pro and Make
Postby IGfortyK » Fri May 03, 2019 7:56 pm
Hello,
I am trying to import CAD linework from AutoCAD Architecture 2018 into SketchUp Pro 2019 and the import is failing every time, no matter how simple the linework is.
I am saving the DWG down (tried each version), I am exploding the linework, and I am removing non-compatible elements (i.e. text, dimensions, etc.).
When I import into SKP19 I see the dialog box in the attached image (of which I am familiar, but have never had issues with). This example was a simple exploded rectangle (5'x10' drawn on the origin point of a new DWG.
We recently upgraded to SketchUp 2019 from 2018 earlier this week. Our import method is the same as before and had no issues prior to using SketchUp 2019.
What could this issue be?
Thank you!
Windows 10 Pro
Processor: Intel Core i5-3570 CPU @ 3.40GHz
RAM: 16 GB
System Type: 64-bit OS, x64-based processor
User avatar
IGfortyK
Re: SketchUp 2019 CAD file import failure
Postby Dave R » Fri May 03, 2019 9:37 pm
Do you have Preserve Drawing Origin selected in the import options?
User avatar
Global Moderator
Postby IGfortyK » Fri May 03, 2019 9:48 pm
Dave R wrote:Do you have Preserve Drawing Origin selected in the import options?
Thanks for the reply.
Yes, I have tried it selected and not selected. Same result.
Windows 10 Pro
RAM: 16 GB
User avatar
IGfortyK
Postby JGA » Tue May 07, 2019 1:44 pm
I had problems with importing DWG into SKUP as well.
Try the following;-
  • Ensure you're working in World UCS and plan is also set to the World UCS.
  • Save back as plain AutoCAD entities to r14 or r12 DWG format.
Regards,
JGA
JGA
Postby IGfortyK » Tue May 07, 2019 9:22 pm
JGA wrote:I had problems with importing DWG into SKUP as well.
Try the following;-
Thank you for the idea. I just tried that, ensuring I was in World UCS as well as exporting down to R14, but the result was the same. I tried exporting to all versions and none seem to change how it is importing.
If this issue was just on my workstation I would probably just reinstall SKP19 but my coworker discovered this issue on her PC before I even attempted on mine.
Windows 10 Pro
RAM: 16 GB
User avatar
IGfortyK
Postby JGA » Wed May 08, 2019 8:38 am
Try dumbing down the plain AutoCAD file even more by exploding some blocks to see if they come into SKUP.
Or
Get the use of your Trimble Support and put a call in - I was surprised and pleased at how quickly I received a reply from them.
Regards,
JGA
JGA
Postby sketch3d.de » Wed May 08, 2019 11:41 am
select all and explode once, save down to the ACAD v2000 format.
User avatar
sketch3d.de
Postby regnar » Sat May 11, 2019 3:09 pm
Another Autocad command to try is 'EXPORTTOAUTOCAD' this might remove any hidden proxys
Windows 10 Professional 64 bit
Intel I9 7900X Asus Prime X299-Delux
Nividia GeForce 1080 TI 11gb
32 GB Ram Samsung 960 EVO Series 1TB PCIe NVMe - M.2
User avatar
regnar
Premium Member
Premium Member
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to SketchUp Pro & Make Discussions
Who is online
Users browsing this forum: No registered users and 7 guests
Visit our sponsors:
