creating a plaid on a chair - cloth simulator?
General discussion related to SketchUp Pro and Make
Postby Jorgensen » Mon Apr 17, 2017 9:36 pm
hi
i wonder if anyone knows of a standalone cloth simulator?
i would like to create a plaid that lays over a chair, like the one in the attached image.
i have tried using artisan, but i'm finding it quite hard (but maybe not impossible) to create something similar.
therefore, does anyone now of a plugin that can simulate cloth in sketchup, or some kind of standalone simulator that imports obj files (the chair) and exports obj files?
any input is very welcome :-)
jorgensen
Jorgensen
Re: creating a plaid on a chair - cloth simulator?
Postby pilou » Mon Apr 17, 2017 11:06 pm
Drape CPoints by TIG can maybe help you!
Speedy Galerie
Top SketchUcator
Postby Jorgensen » Thu Apr 20, 2017 4:40 pm
hi pilou
thanks - drape cpoints looks very interesting. i will test that out.
thanks
jorgensen
sketchup pro 2016 16.1.1449 64 bit | windows 10 pro | i7-3770k @3.5 GHz | 16gb ram | gtx 780 ti / gtx 980 ti | nvidia driver 368.39
Jorgensen
Postby faust07 » Fri Apr 21, 2017 1:38 pm
Maybe you can also use SketchyPhysics for it. Possibly there is this technique once for MSPhysics. This example is made with models from 3D-Warehouse and the plugin "SketchyPhysics" (only up to SketchUp 2016, 32 bit).
3
faust07
Postby Rich O Brien » Fri Apr 21, 2017 2:06 pm
Cool!
Rich O Brien
Administrator
Postby Jorgensen » Fri Apr 21, 2017 4:01 pm
hi faust
that is so cool - i have tried to install MSPhysics in sketchup 2017, and it seems to run - do i need more than that?
thanks
jorgensen
Jorgensen
Postby Jorgensen » Fri Apr 21, 2017 4:05 pm
and how the ..... have you made that fantastic cloth? :-)
i don't see that as a material type...
Jorgensen
Postby HornOxx » Fri Apr 21, 2017 4:46 pm
faust07 wrote:Maybe you can also use SketchyPhysics for it...
:o WOW !!!
HornOxx
Postby solo » Fri Apr 21, 2017 4:52 pm
What trickery have we here? :mrgreen:
So damned cool.
www.solos-art.com
I'm a social vegan, I avoid meet.
solo
Global Moderator
Postby cuttingedge » Fri Apr 21, 2017 6:16 pm
(sketchy Physics) didnt know that it has that capability at all .they've been sitting on my toolbar for a long while....
cuttingedge
Postby pilou » Fri Apr 21, 2017 6:16 pm
You must have also AMS Library!
Speedy Galerie
Top SketchUcator
Postby Jorgensen » Fri Apr 21, 2017 6:19 pm
Ok. Have that.
I was just surprised that it works in sketchup 2017 / 64 bit.
Jorgensen
Jorgensen
Postby faust07 » Fri Apr 21, 2017 7:06 pm
As I wrote, this runs only with "SketchyPysics" up to the SketchUp version 2016 32 bit. It still does not work with "MSPhysics" (SketchUp 2017, 64 bit). But the author of the plugin (Anton S) has something similar on his ToDoList.
The assignment of material is only possible after reaching the intended position of the cloth and storing a copy of the model during the pausing simulation.
faust07
Postby faust07 » Fri Apr 21, 2017 8:28 pm
and here is the model, if you want to play...
The mesh count of the cloth can be increased by copying the elements accordingly and adjusting the numbering of the matrix ...
Two very interesting techniques have been used: self-linking groups and the creation of a surface following the simulation.
The model is a little bit modified by me (sorry, don't know the name of the author and can't find it on 3D-warehouse, only copies...)
If this could be translated for MS Physics one day - Hallelujah :enlight:
faust07
Postby Anton_S » Fri Apr 21, 2017 8:32 pm
Actually this can be done with MSPhysics. All this does is creates a bunch of speres linked by BallAndSocket joints. Then it uses a script to move cloth vertices to new position. This is artificial cloth and has its downsides, primarily the performance. But I can modify that small script for compatibility with MSPhysics.
Anton_S
PluginStore Author
PluginStore Author
Postby faust07 » Fri Apr 21, 2017 8:37 pm
Ingenious, I've known it... Thanks, Anton! :fro:
faust07
Postby Jorgensen » Fri Apr 21, 2017 8:52 pm
So it might work with msphysics?
I hope as I don't have access to su 2016 anymore.
Jorgensen
Postby cuttingedge » Sat Apr 22, 2017 4:15 am
a proof of concept to creating like "Marvelous Designer " plugin perhaps. Are we still decades away from there?
cuttingedge
Postby Anton_S » Wed Apr 26, 2017 1:14 am
Here is the proof!
I intend of writing a new plugin for this kind of stuff.
7
Anton_S
PluginStore Author
PluginStore Author
Postby Jorgensen » Wed Apr 26, 2017 5:18 am
That would be very very cool Anton!
It would make cloth creating a lot easier.
Just create a flat cloth, add a nice texture, animate the cloth onto a chair, stop the animatin, make small adjustments with artisan or like - and render.
Can we set the resolution of the cloth?
Jorgensen
Jorgensen
Postby Anton_S » Wed Apr 26, 2017 8:36 am
Yes, Jorgensen,
The resolution is dependent on the number of vertices of your cloth or any other deformable mesh. If you have a plane made up of many vertices, the the number of bending vertices will be as much. Before getting it fully working, I need to make the faces in between the vertices to be collidable as well. That way things in between, such as the edges of the table shown in the video, won't intersect the cloth. I also need to make different constraints for the nodes that will allow the deformable mesh to stretch and unbend, such as for making a tire, a gummybear, or a sofa, or anything squishy.
I'm still trying to decide whether to include it in the upcoming release of MSPhysics or write a new plugin that will specifically focus on soft body simulations.
Regards,
Anton
Anton_S
PluginStore Author
PluginStore Author
Postby pilou » Wed Apr 26, 2017 10:03 am
Except some little tears that is marvellous! :enlight:
Speedy Galerie
Top SketchUcator
Postby Jorgensen » Wed Apr 26, 2017 12:06 pm
hi anton
my personal thought - release it as quick as possible :-)
but if i was you, i would design it as a "cloth plugin" for sketchup, that makes it very clear what the plugin is used for - and consider make it a "pay for" plugin - good plugins takes time to develop and i'm sure people will pay, if the quality is there :-)
thanks
jorgensen
Jorgensen
Postby Pixero » Wed Apr 26, 2017 12:38 pm
Do what ever is easiest for you development wise.
A cloth simulator would be awesome.
Making it work with Thomthoms subD would be prefered.
Don't think too long.
Just do it! :thumb: :D
3
Pixero
Premium Member
Premium Member
Postby solo » Wed Apr 26, 2017 1:31 pm
I vote for a stand alone cloth simulator, great work by the way.
3
www.solos-art.com
solo
Global Moderator
Postby faust07 » Wed Apr 26, 2017 2:00 pm
Great examples in your video, Anton! And it seams to work in MSPhysics.
A simple variant for MSPhysics would also be welcome.
This would make moving objects made of flexible materials more natural.
The problem of interpenetration of the partial surfaces could be solved temporarily with larger hidden body parts.
faust07
Postby juju » Wed Apr 26, 2017 2:18 pm
Definitely a separate cloth simulator, pretty please!
juju
Premium Member
Premium Member
Postby Anton_S » Wed Apr 26, 2017 3:50 pm
Thank you all for your suggestions! Now suggestions for the name of the plugin and some upfront ideas would be great.
Right now I'm thinking of naming it, SoftWorks.
The plugin will have a UI for controlling the selected deformable groups' mass, stiffness and linear/angular acceleration/damper.
There will also be a toolbar.
One toolbar button will allow dropping/simulating the selected or all the deformable bodies until a stop button is pressed, which will freeze​ all/selected in place.
Another button will allow resetting the original placement of all/selected bodies.
And another button will allow toggling the UI.
Another two will allow adding Fixed and Slider constraints in places. The touching cloth will automatically will be connected to the constraints.
As for the back ground, all other non-ignored visible groups/components will act as static/movable solid bodies.
There will also be options for exporting animations.
These are the ideas for now. Suggestions that will guide me in the right way would be nice.
Thanks!
3
Anton_S
PluginStore Author
PluginStore Author
Postby solo » Wed Apr 26, 2017 3:58 pm
'Softworks' works for me, now shut up and take my money already. :mrgreen:
3
www.solos-art.com
solo
Global Moderator
Postby faust07 » Wed Apr 26, 2017 4:02 pm
There are several firms in the world with the name "Softworks"...
Regarding the functions of the plugin you are on the right way.
It sounds like a little bit of a baby of MSPhysics outside of the physics world.
Please don't forget the mother... ;)
faust07
Next
Return to SketchUp Pro & Make Discussions
cron
Users browsing this forum: Google Bot and 9 guests
