Urgent help!!!!! Pushpull Problem (SOLVED)
General discussion related to SketchUp Pro and Make
Postby holmes1977 » Mon Sep 15, 2014 1:10 am
Hi Guys
I have come across this problem in the past and solved it. But can't remember and cant find any solutions online. There are 2 problems which must be linked together.
PROBLEM 1
PROCESS
1.) I draw a square (4 lines and a face)
2.) Use the push/pull tool to form a cube
RESULT
The square (4 line and a face) moves in the direction I use the push/pull tool without forming a cube.So it acts like the move tool.
PROBLEM 2
PROCESS
1.) Select the paint bucket tool
RESULT
Instead of the paint bucket tool appearing the select paint (eye dropper) appears.
Exaggeration makes a dull story better.
User avatar
holmes1977
Re: Urgent help!!!!! Pushpull Problem
Postby Krisidious » Mon Sep 15, 2014 1:50 am
You're sure your mouse isn't having issues?
By: Kristoff Rand
Home Designer
Unique House Plans
User avatar
Krisidious
Postby S Shepherd » Mon Sep 15, 2014 2:13 am
I think you may have a stuck alt key on your keyboard.
Shep
User avatar
S Shepherd
Postby Dave R » Mon Sep 15, 2014 2:22 am
I would concur with Scott. Both of those behaviors are the things you would expect from those tools when the Alt key is held down.
User avatar
Global Moderator
Postby holmes1977 » Mon Sep 15, 2014 2:43 am
Hi Team
Like I said this has happened before.
I re-installed nvidia drivers and the problem has solved itself. Like you guys, it felt like a stuck key problem. I do remember now that re-installing graphics driver fixed it last time. How that seems to effect certain tools in SU I have no idea.
Thanks so much for your help
User avatar
holmes1977
Re: Urgent help!!!!! Pushpull Problem (SOLVED)
Postby Dave R » Mon Sep 15, 2014 2:46 am
Weird but I'm glad you figured it out.
User avatar
Global Moderator
Postby panixia » Fri Sep 19, 2014 9:32 am
Dave R wrote:Both of those behaviors are the things you would expect from those tools when the Alt key is held down.
what a "doh" moment! :o never noticed the pushpull+alt quickly moves faces without extruding them.. this could be handy sometimes.. thank you! :P
User avatar
panixia
Postby ely862me » Fri Sep 19, 2014 9:59 am
Not for me ... ?!?
Elisei (sketchupper)
____________________________________________________________
Come and See EliseiDesign
User avatar
ely862me
Top SketchUcator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to SketchUp Pro & Make Discussions
Who is online
Users browsing this forum: Google Bot and 8 guests
Visit our sponsors:
