Thickness Ruby to make shell?
General discussion related to SketchUp Pro and Make
Postby marvins_dad » Wed Feb 27, 2013 5:36 pm
I've been doing a lot of 3d printing lately. Mostly the volumes have been a modification of something or simple volume.
I understand that in order to get the object to print properly it needs to have a completely closed volume.
The question I have for you guys after searching and not finding a solution...
Is there a ruby out there that will create an offset or "shell". I have a car shell that I am working on that I want to print as a 1/6" thick lightweight shell to attach to something else...similar to an RC car shell. The problem is that I have created the shape of the shell I want, but the programs won't simply print along a plane with zero thickness.
Any ideas?
antoine
marvins_dad
Re: Thickness Ruby to make shell?
Postby Rich O Brien » Wed Feb 27, 2013 5:47 pm
Fredo's Joint Push Pull?
Rich O Brien
Administrator
Postby marvins_dad » Wed Feb 27, 2013 6:18 pm
Rich O Brien wrote:Fredo's Joint Push Pull?
I have that installed...will try it at lunch...initial attempt crashed the program, but maybe if I am more selective it might work.
Thanks Rich
marvins_dad
Postby dukejazz » Wed Feb 27, 2013 6:20 pm
My plugin will make a shell
[Plugin] scaleGroupFloat_dj Ver 1.6.5 Feb 15, 2013 by dukejazz » May 11th, 2012, 3:36 pm
Copyright Feb 15, 2013
DukeJazz: by James Cochran
has a tool call
cumulativeScaler_dj (now dose xyz x y z scale,step and rotation)
viewtopic.php?f=323&t=45254&start=15
dukejazz
Postby cotty » Wed Feb 27, 2013 7:41 pm
And there is Thomthoms shell plugin.
cotty
Top SketchUcator
Postby marvins_dad » Wed Feb 27, 2013 8:08 pm
dukejazz wrote:My plugin will make a shell
has a tool call
I can't figure it out...all I have been able to do is an offset.
Looking to basically create a 1/16" shell.
marvins_dad
cotty wrote:And there is Thomthoms shell plugin.
Looks perfect...but can't get it to do anything. :(
marvins_dad
Postby jeff hammond » Wed Feb 27, 2013 8:26 pm
Thanks Rich
did it crash or appear to hang?
if you're doing a processor intensive operation in sketchup, it may appear as if its not working.. but it is.
(for reference, I once did a jpp operation that took 4 hrs to calculate)
dotdotdot
jeff hammond
Global Moderator
Postby gilles » Wed Feb 27, 2013 8:31 pm
works with groups or components, did you try on raw geometries?
gilles
Top SketchUcator
Postby marvins_dad » Wed Feb 27, 2013 8:38 pm
Thanks Rich
I get a "SketchUp Application has stopped working" dialog box...only options are check online and close or close program. Problem signature:...APPCRASH
marvins_dad
Postby marvins_dad » Wed Feb 27, 2013 8:39 pm
gilles wrote:works with groups or components, did you try on raw geometries?
I was trying with raw geometries...I'll try with a group...are you talking about "Shell"?
marvins_dad
Postby marvins_dad » Wed Feb 27, 2013 8:45 pm
Shell seems to preview when I select a group and I can see the offset and adjust it. When I double click it doesn't stay...when I hit enter nothing happens. When I double click then click outside the group the offset disappears.
What am I doing wrong?
marvins_dad
Postby gilles » Wed Feb 27, 2013 8:48 pm
I do.
gilles
Top SketchUcator
Postby gilles » Wed Feb 27, 2013 8:50 pm
Adjust the fitness, then Enter, then double click.
gilles
Top SketchUcator
Postby marvins_dad » Wed Feb 27, 2013 8:55 pm
gilles wrote:Adjust the fitness, then Enter, then double click.
Okay - I tried on a portion that wasn't as complex and it worked.
Looks like I need to simplify my model a bit (clean it up) and try again.
Thanks!
marvins_dad
Postby dukejazz » Thu Feb 28, 2013 2:00 pm
I have a tool call cumulativeScaler_dj
it's part of scaleGroupFloat_dj package (doses cumulative xyz, x, y, z, scale,step,move and rotation)
by marvins_dad » Yesterday, 12:08 pm
I figure it for you.
I found a car body on 3d warehouse
and I work it 1/16 but it's not close yet for a volume
car+body16_dj.skp
dukejazz
Postby dukejazz » Mon Mar 04, 2013 1:41 pm
I rework it and now it's a closed shell volume:
by these steps
1) I started wuth the car body
2) draw with line tool and close the volume
3) I copy and offset scaled by 1/16 inch as before with scaleGroupFloat_dj
scaleGroupFloat_dj will create an offset call "shell". the settings shown ealier above
4 ) I then vector push-pull the wheels acoss
5) right click and used context intersect face to model
6) cut away
and then cut the bottom interial face of the car
by marvins_dad » February 27th, 2013, 9:36 am
Is there a ruby out there that will create an offset or "shell". I have a car shell... 1/6" thick lightweight ... The problem is ... the programs won't simply print along a plane with zero thickness.
and now marvins
The Answer:
yes- Use scaleGroupFloat_dj.rb
and a vector push-pull tool
(=to SU push-pull then one end exploded face move by the move tool)
by the process above you get this
car+body16_dj.skp
dukejazz
Return to SketchUp Pro & Make Discussions
