poser to sketchup?
General discussion related to SketchUp Pro and Make
poser to sketchup?
Postby jo-ke » Sun Sep 09, 2012 12:23 pm
I would like to export characters that I've created in poser to sketchup.
To do this, I have to reduce poly, because the characters are to highpoly for SU. I think meshlab is a good choice to do that.
I tried different things but I had no success to import low poly characters with textures in SU.
Has anybody tried that too and could give me some advices?
jo-ke
Premium Member
Premium Member
Re: poser to sketchup?
Postby renderiza » Sun Sep 16, 2012 9:05 am
Artisan plugin has a tool to reduce polygons but the texture will get screwed. So you will have to make new UV’s. I believe TGI 3D plugin has a tool to make UV’s but don’t know if it will tackle a complex geometry properly.
Good luck!
renderiza
Premium Member
Premium Member
Postby numbthumb » Sun Sep 16, 2012 9:46 am
viewtopic.php?f=79&t=25192&p=310088
I´m afraid that they´re almost unusable unless you go for some serious poly-reduction. Or in that case you´re better of starting from scratch :?
Have you tried MakeHuman?
Comfortably numb...
numbthumb
Top SketchUcator
Postby jo-ke » Sun Sep 16, 2012 10:19 am
I just came to this idea, because I've seen such great characters in 3ds format at archive3d.net. They look like created in max or poser or a program like that. I have many nice characters in poser in I would like to see them in my scenes. I have even problems to export them from poser to obj or 3ds, because they are to heavy. I think there must be a way to reduce them in an early stage of process. All these things should happen before importing them to sketchup because they are much to highpoly.
I tried makehumen some years ago but that brought me to poser/DAZ Studio because there are much more posibilties.
jo-ke
Premium Member
Premium Member
Postby Khai » Sun Sep 16, 2012 10:38 am
frankly, you won't do it. I use Poser and Sketchup together as well, and basically, SU cannot handle the Poly counts of the simplest poser figure in any useful fashion. (Eg Posette, the basic Poser 4 human female, she's 40,000 polys, that's without clothes... a Victoria 3 or 4 is 60-90K)
you need to reverse your thinking and go the other way. SU to Poser. it's easy enough with the OBJ export scripts or if you have poserpro, Collada.
Khai
Postby jo-ke » Sun Sep 16, 2012 9:42 pm
I tried that also, but I was missing my materials from twilight render. I'm not really into firefly.
In the past I rendered the scene in SU/twilight and the characters in poser and merged it together in Photoshop.
Maybe I should look a bit better at firefly.
jo-ke
Premium Member
Premium Member
Postby jo-ke » Sun Oct 14, 2012 4:55 pm
here's an example:
room modelled in su and rendered in twilight.
person rendered in poser.
merged together in photoshop
jo-ke
Premium Member
Premium Member
Return to SketchUp Pro & Make Discussions
Users browsing this forum: faust07, Pa0l0k and 22 guests
