for some time I find the backup Skb files in the Plugins folder and in my Kerkythea project folder . I do not know why. Is there a way to select a specific folder for the Skb-files? I appreciate any helpful hints.
Charly
Question: Backup Files at different Folders!
• Page 1 of 1
Question: Backup Files at different Folders!Hi,
for some time I find the backup Skb files in the Plugins folder and in my Kerkythea project folder . I do not know why. Is there a way to select a specific folder for the Skb-files? I appreciate any helpful hints. Charly Please, register (free) to access all the attachments on the forums. More dangerous than ignorance is the illusion of knowledge
Re: Question: Backup Files at different Folders!Hmmmmm...it should be saving the skb file wherever you save the skp file.
You might try checking the preferences, and check the path name for saved models. Please, register (free) to access all the attachments on the forums. What I lack in depth I make up for in shallowness. Gomez Adams
Re: Question: Backup Files at different Folders!Hi Daniel,
thank you for your answer. The paths in the preferences I had checked first. Charly Please, register (free) to access all the attachments on the forums. More dangerous than ignorance is the illusion of knowledge
Re: Question: Backup Files at different Folders!If you are working over a [slow] network or perhaps on a memory-stick etc the time-out in the saves can dump a SKB in an alternative location - like ../Plugins/...
When a SKB is made there's some file shuffling with the names and file-types so a temp name is used. Hence the odd names like '2.skb'... TIG
SketchUcation One-Liner AdvertsAre you a Premium Member? Get your freebies here. Are you not> a Premium Member yet? Upgrade your account to grab these freebies instantly.
• Page 1 of 1
