SketchUcation Plugin Store
Right click axis show errors in ruby console by plugins
General discussion related to SketchUp. No off topic threads please.
Postby dukejazz » Sat Jun 16, 2012 7:41 pm
Just by right clicking on axis for it's context will show errors in a open ruby console, cause by some ruby loaded plugins.
Is this just my sketchup setup only or do some one else's with alot plugins see this too?
I had a page and haft of error ... I unloaded 6 plugins and still have one left to find.
Error: #<LocalJumpError: unexpected return>
(eval):107:in `load'
Why dose this happen? (must be bad code or conflick)
dukejazz
Operating system: Windows
SketchUp version: 7
License type: Free/Make
SketchUp use: hobby
Re: Right click axis show errors in ruby console by plugins
Postby dukejazz » Sat Jun 16, 2012 8:23 pm
Example
The loaded plugin zorro2.rb
D:\P\Google\Google SketchUp 8m3\Plugins\Zorro2.rb:650
(eval):107:in `call'
(eval):107
dukejazz
SketchUp version: 7
SketchUp use: hobby
Postby thomthom » Mon Jun 18, 2012 10:15 am
That's usually a result of people using return to exit a block instead of break.
Global Moderator
Name: Thomas Thomassen
SketchUp version: 2013
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Postby dukejazz » Tue Jun 19, 2012 9:25 am
@650 return method 647-656
Code: Select all
UI.add_context_menu_handler {|menu|
   sel=Sketchup.active_model.selection.first
   menu.add_separator
   return if not sel
   if sel.class==Sketchup::SectionPlane
         menu.add_item("Slice Model at Section") {Zorro2Tool.new.slice_model_at_section(sel)}
         #menu.add_item("Slice Context at Section") {}
Ruby console pannel show
D:/P/Google/Google SketchUp 8m3/Plugins/Zorro2.rb:650
(eval):107
@650 break method 647-656
Code: Select all
   menu.add_separator
   break if not sel
Error: #<LocalJumpError: break from proc-closure>
D:/P/Google/Google SketchUp 8m3/Plugins/Zorro2.rb:650:in `call'
(eval):107return
sel = nil
Both block methods fail?
Thomthom you know more than I.
by thomthom on Mon Jun 18, 2012 2:15 am
That's usually a result of people using return to exit a block (true)
so by getting rid of return line (#return if not sel)
and adding to the 651 line if statement (and is sel)
Code: Select all
   menu.add_separator
   #return if not sel
   if sel.class==Sketchup::SectionPlane and is sel
This seem to fix the zorro2.rb code.
Thank you, for your help, Thomthom on Mon Jun 18, 2012 2:15 am -jwc
dukejazz
SketchUp version: 7
SketchUp use: hobby
Postby thomthom » Tue Jun 19, 2012 10:03 am
Replace this:
return if not sel
With this:
if sel && sel.class==Sketchup::SectionPlane
Global Moderator
License type: Pro
Need Authorised SketchUp Training by experts in various disciplines? Check out our Training details.
Return to SketchUp Discussions
Users browsing this forum: JacobW and 9 guests
