Bravo to you too.
Here's my slight reworking of your brilliant ideas, with some explanatory notes.
I think this way is a little simpler and easier to see what's happening.
mini-challengeRe: mini-challengeVERY clever Pilou !
Bravo to you too. Here's my slight reworking of your brilliant ideas, with some explanatory notes. I think this way is a little simpler and easier to see what's happening. ![]() Please, register (free) to access all the attachments on the forums. TIG
Re: mini-challengeIn the example, why push pull up on the face? The whole point seems to be to find Point 'B'. (diagram THAT clause
Maybe this is beyond my maths. True: the center cut line in the first picture does describe the center of the final board, call it point 'X'. B is a right angle from 'X' but it's a right angle from the board's diagonal, not from the final axis of the board. Still it lies on the edge of the board a distance d/2 from point X? Please, register (free) to access all the attachments on the forums.
Re: mini-challenge@TIG
Cool but there is a little mystery In your file (from the mine modified) tichkness is not 1.000000m but 0.997509m CD = 1.320818 m Or you don't change the drawing and just type the text's explanations for only the theory? In a nurbs modeler with the Technic of circle (first example of Jeff video) (with of course sames measures) CD = 1.3239127 m & angle 40.945192° The adventure is not finished! File nurbs format 3dm Please, register (free) to access all the attachments on the forums.
Re: mini-challengeGilles,
I Have no idea how you figured that out Peter
Re: mini-challengeGood try but...
Re: mini-challengePilou's version appears to work...
But when I reproduce it there's inaccuracy again Logic [initially] says that offsetting [pushpulling] a face that is coplanar with the known diagonal by width/2 and then adding the new sloping lines through the points ought to make them along the rail's raking edges ??? BUT the offset is perpendicular to the diagonal NOT the rails sides ! Hence the errors... very much like all other approximation methods TIG
Re: mini-challengeTIG,
To me the problem is that d/2 should be measured perpendicular to the final edge, not the diagonal. Peter
Re: mini-challengeExactly right - I was adding that to my last post as you posted... The difference between offsetting the diagonal and the sides is the error. TIG
Re: mini-challenge
Indeed - components interacting with each other during manipulation has always been baffling to me. Some things work and some don't (for example try to move a line in a mirrored component so that it's on the mirror plane - it won't snap to the other side, it'll just keep going past the mirror plane)
Re: mini-challengeI have yet another 'drawn' solution...
I can't fault it... but then again... you might... Please, register (free) to access all the attachments on the forums. TIG
Re: mini-challenge
that appears to work... instead of copying the line up by the thickness of the brace, i +rotated about the center of the original line 180d. then traced over everything to get my shape. except, when i use the tape, with 0.000000 accuracy, i get 5.995197, instead of what should be 6" in my example. copying the bottom line up 6" (2x the measurement i used for 1/2w) should yield better results, but then i'd guess that the top or bottom would be off. or the rotate tool is inherently inaccurate.
Re: mini-challenge
The line was not here but exist so you can interact with, I use this technic frequently.
Re: mini-challengeMove+Ctrl to copy the bottom long-side lines up to 'T' [as there are two lines, split by the width/2 perpendicular line...] moved up to the top of the right-hand post [T]... TIG
Re: mini-challengeAnother working solution [I think!]... but it uses a script TIG
Re: mini-challengeA script that should be a default tool
If only Google accepted sketchUcation's offer to buy Sketchp that time
Re: mini-challengeI know... I know... but we are now all Trimblers-in-our-boots TIG
Re: mini-challenge
Without doing a test, I don't see the logic that when you rotate the line back up, that point E hits the diagonal at any meaningful (or snappable) point. It can't be hitting the 'M' midpoint of the diagonal... therefore it isn't width/2 off the true axis of the board. In fact, isn't the angle created the same as measuring width/2 from M to the bottom edge?
Re: mini-challengeThat's was the point... you snap it to M but E can never 'touch' it - but it will align... landing on the centerline.
BUT... you have me 'banged to rights' - it doesn't work as it's not an exact fit, so there is still a tolerance issue Back to the drawing board... TIG
Re: mini-challengebeen watching with no spare time...
my solution, two instances of square component, the second moved to top of target post and rotated 180º, then in edit mode rotated again from pivot point and snaped to first instances [also rotating] none pivot corner. john Please, register (free) to access all the attachments on the forums.
Re: mini-challengeDriven
I think this a variation of the two-instance-rotation-with-mutual-snapping solution posted earlier today... Can you elaborate... So far, I think that is the only good way [along with Fredo's weird snap inferencing example] ??? TIG
Re: mini-challengeTig,
your most likely right, I haven't had a good look at all the 'solutions' I'm working 18hr days at the moment and just had a quick shot at it, needed a play before sleep... john
Re: mini-challengeHere is improved on solution I posted early and all dimension have been verified to SU 32 bit float accuracy against the close form solution I presented above.
Note I have been using some of the post dimension Jeff posted early of 96" post height, 65" spacing and 3.5 rail width. No plugin is used. I did use the technique I posted almost a year or so ago on the exact solution of sphere line intersection. Please, register (free) to access all the attachments on the forums.
Re: mini-challenge
Hey Mac1 - what "sphere" are you using? It's not clear in your model what your steps are.
Re: mini-challenge
Sorry did not make my self clear enough for you. At the bottom right I show the intersect point, at the bottom left I show the center of the sphere. Since SU is a 3d program any time you talk about intersecting a rotated line with a target line it must be on a spherical basis. There was no intent to show a sphere but the math basis must consider that or you do not have a closed form solution. SO the directed line segment from the line rotation point ( aka center of sphere) to the intersection of the target line( used as ref for guide point) is the points one needs to get the angle of rotation and the intersect with the rail width to the left post. SO the intersect ( guide point ) at the target line, the two 3.5 inch spaced guide lines are all rotated to the top of the left post to establish the points needed to draw the 3.5 rail to the proper points. Here is a screen shot of the skip file I posted some time ago. Please, register (free) to access all the attachments on the forums.
Re: mini-challengeBTW you need ground truth to know if your model is correct. I presented the closed form solution for the 2d case above. Here is the excel results to check my model' Please, register (free) to access all the attachments on the forums.
Re: mini-challengeThe fact that this thread is already 19 pages long has made me seriously consider learning either MoI or Rhino.
Re: mini-challengeTake Moi : It's the SU of Nurbs against Rhino !
Less powerful functions but it's not the same spirite! I don't abort to find a more easy answer at this damned problem of align rotation who fail at mini micro sub-atomic snaping! Last edited by Pilou on Fri May 04, 2012 12:11 am, edited 1 time in total.
Re: mini-challenge
Clear as mud You still don't show your steps. I'd love to see the "sphere" you are using, or are you just talking about calculating and not modeling. Sure, anyone understanding basic trig can calculate the length of the edge based on the diagonal, that's been done a few times in this thread, but entering numbers seems to still end up with rounding errors in SU...
Re: mini-challengeGreetings all,
A few months back I had a similar conundrum..........after fussing a bit I just "eyeballed it" to get my cross bracing. "Knowing" the challenge, I have taken another swing at it...........though it still does not "zero out". In short.........center the cross brace and scale it's "ends" to meet the vertical(s). Sorry..........I do not possess video skills. Best, Please, register (free) to access all the attachments on the forums.
SketchUcation One-Liner AdvertsNeed SketchUp Books, Models, Styles or Textures? Check out our One Stop Shop for SketchUp.
