so I downloaded the latest and greatest of SP3 and on the start up I get this. . .
and when I press the Play button I get this. . .
any thoughts?
Filling a Space with Components.
• Page 1 of 1
Re: Filling a Space with Components.so I downloaded the latest and greatest of SP3 and on the start up I get this. . .
and when I press the Play button I get this. . . any thoughts? Please, register (free) to access all the attachments on the forums. If I make it look easy. . .rest assured--it probably is.
Re: Filling a Space with Components.Ah damned
I am affraid to say that I don't know why you have this sort of thing Try to install a previous versions of Su That I shown was done with a recent version of Sketchyphysics on an old SU 7 version Another thing : seems Sketchyphics makes some interference with some other plugs so disable it when you don't use! I just change the name of its extension ".rb" as ".rbo" in the plugin folder
Re: Filling a Space with Components.I was afraid of that. I've only got 1400 Plugins that could be the problem. Should be no problem going through all of them.
Re: Filling a Space with Components.Save somewhere the folder Plugins
Create a new folder Plugins Install Sketchyphysics run it but from you error messages I doubt that will be sufficient
Re: Filling a Space with Components.it usually never is--
when it comes to me, but I will give it a try. Thx, d If I make it look easy. . .rest assured--it probably is.
Re: Filling a Space with Components.I'd give component spray a whirl. It is fast and polite. Try it with a simple 3d tick of the same cross dims as your balls, then redefine the component as you wish if it works out.
Please, register (free) to access all the attachments on the forums. ~ Brooke
SketchUcation One-Liner AdvertsKeyframe Animation plugin - animate your SketchUp model by adding movement to any object.
• Page 1 of 1
