The "Duh!" thread (aka the Doh! thread)
General discussion related to SketchUp Pro and Make
Re: The "Duh!" thread (aka the Doh! thread)
Postby L i am » Mon Jan 01, 2018 2:52 pm
You probably missed this, too. If you want to place the same radius on other corners, double click near them.
Thank you, thank you, thank you!
Premium Member
Premium Member
Postby david_h » Wed Jan 09, 2019 7:47 pm
I know I should know this (being a top sketchukator and all--- :mrgreen: Yeah, I am having a hard time containing my laughter too. . .)but as I said. .I know I should know this but I don't:
as I go between scenes with sections how can I toggle between them and keep the section plane window off so I dont have to manually turn them off each time? I have always found the scene menu in SU very confusing and conveluted and I can't seem to get this to work as I want. Help please? Thanks.
David_H
If I make it look easy. . .then it probably is.
david_h
Top SketchUcator
Postby Dave R » Wed Jan 09, 2019 7:50 pm
David, you can access them in the Outliner. Right click on the desired section cut in Outliner and activate it or deactivate as needed.
Global Moderator
Postby david_h » Wed Jan 09, 2019 7:59 pm
Dave. . thanks for the response and please excuse the follow up. . . I guess I'm not following, or i didn't make my question clear and I don't use outliiner that much. . .is there a way to save the scene updates so that the windows just stay off? I don't see how Outline does that for me.
Thx,
D
david_h
Top SketchUcator
Postby david_h » Wed Jan 09, 2019 8:01 pm
Never mind. .. I think I got it. I just update after the outliner thing. Correct?
Thx,
D
david_h
Top SketchUcator
Postby Dave R » Wed Jan 09, 2019 8:13 pm
Oh. Sorry. I didn't get that part. The display of section planes is a style setting thing so edit the style to turn them off, update the style and update the scenes.
Actually, if you edit the style and then update the scene, you should get a warning that tells you the style has been edited and asking if you want to update the style or create a new one.
Global Moderator
Postby david_h » Wed Jan 09, 2019 8:26 pm
Thank you! it's really quite amazing how much of the basic stuff you forget when you don't dealwith it that often.
D
david_h
Top SketchUcator
Postby Dave R » Wed Jan 09, 2019 8:41 pm
Yes it is amazing indeed.
And it shows how deep SketchUp can be.
Global Moderator
Postby rv1974 » Wed Mar 13, 2019 2:13 pm
Curic Extend is amazing!
https://gumroad.com/curic
50% discount code:
10k followers
rv1974
Postby pilou » Wed Mar 13, 2019 3:39 pm
A tool EXTRUDE EDGES BY VECTOR BY tig don't make the same ? ;)
3
Speedy Galerie
Top SketchUcator
Postby rv1974 » Wed Mar 13, 2019 4:28 pm
no, Curic works with multiple independent objects (groups, components) and\or its faces instantly.
Does Tig's one extrude to a curved object?
rv1974
Postby Dave R » Wed Mar 13, 2019 4:34 pm
rv1974 wrote:Does Tig's one extrude to a curved object?
Yes.
Global Moderator
Postby rv1974 » Wed Mar 13, 2019 5:22 pm
Very good, but once again ability to process multiple objects regardless the context makes night and day difference.
rv1974
Postby TIG » Wed Mar 13, 2019 7:00 pm
rv1974 wrote:no, Curic works with multiple independent objects (groups, components) and\or its faces instantly.
My EE... tool extends selected edges and by connection their faces to any objects in the way of the vector-path, or a picked point on that path - whichever is appropriate. It doesn't process the contents of selected groups etc, so you must edit them and select the geometry to process.
The objects to which it extrudes must include some faces [even if nested inside groups etc] - so curved surfaces are accommodated...
Global Moderator
Postby Khai » Thu Mar 14, 2019 8:34 am
My biggest Doh!
Struggling with microfaces on a component..
Brain : this is a component!
Me : I know
Brain : no, this is a component, get it?
Me : I know! Will you shuv up?
Brain : idiot. Copy it, enlarge it 500% over there, and then work on it, they won't be microfaces anymore and life will be easy. Pillock.
Khai
Postby Box » Thu Mar 14, 2019 9:28 am
Why on earth is Curic Extend in this thread!
If you want to post it put it in a thread of its own in the Plugins SubForum.
4
Postby Dave R » Thu Mar 14, 2019 1:10 pm
Khai wrote:My biggest Doh!
Me : I know
As demonstrated by Box:
https://sketchucation.com/forums/viewto ... 18&t=68150
Global Moderator
Postby david_h » Mon Mar 25, 2019 4:22 pm
Fellow Wizards:
so in previous versions of SU there was a blue icon with a query (?) symbol or something that would give you all the statistics of a model and the ability to fix and purge throughout. What happened to that too in V 18? Entity Info doesn't quite do it for me.
thx,
D
david_h
Top SketchUcator
Postby Dave R » Mon Mar 25, 2019 4:28 pm
david_h wrote:so in previous versions of SU there was a blue icon with a query (?) symbol or something that would give you all the statistics...
I suspect you mean the Query tool which creates something that looks like this:
That is part of the Utilities Tools available from the Extension Warehouse.
Global Moderator
Postby david_h » Mon Mar 25, 2019 4:31 pm
Thanks Dave. No. . it was a statistics tool of some kind. I didn't use it much but I need it today to find out where some problems are and that it can fix them.
It had a menu that would come up that would show all the entities and an option to fix problems etc.
again, Thanks.
D
EDIT: This just in:
I think I found it!
thx again.
david_h
Top SketchUcator
Postby Dave R » Mon Mar 25, 2019 4:35 pm
CleanUp3? TIG's Purge All?
Do you still have the older version of SketchUp installed so you could check to see what it is called?
Global Moderator
Postby david_h » Mon Mar 25, 2019 4:39 pm
It was in the Window Menu. I just did't know to look for it there cuz it had it's own toolbar icon but it doesn't now.
So. . . .
david_h
Top SketchUcator
Postby pilou » Thu May 09, 2019 9:47 am
A cool one never too late! :mrgreen:
- Draw a box
- Draw a Line Guide in whatever direction wished
- Release the mouse and type any integer fraction N/D in the VCB with your 2 hands! :)
7/3 for example...
(any time you want till the good position of the Guide line wished! :fro:
I don't know why that works not with N*D or N+D or N-D :?:
Speedy Galerie
Top SketchUcator
Postby pilou » Thu May 09, 2019 10:14 am
With the same tool : how to draw an only one Guide Point in the Space without plugin! :)
Draw with the Tape tool any one Guide point on an Edge (not on an hot point)
(on a middle edge you can't draw a guide point)
Move this Guide Point in the space
Et voilà :)
Speedy Galerie
Top SketchUcator
Postby slbaumgartner » Sat May 11, 2019 1:45 pm
pilou wrote:I don't know why that works not with N*D or N+D or N-D :?:
It works with N/D as a side effect of supporting fractional inches. Though it's a common request, the measurement box doesn't support arithmetic and doesn't really understand division other than integer ratios.
slbaumgartner
PluginStore Author
PluginStore Author
Postby Bep » Wed Jul 31, 2019 11:13 am
Don't make this mistake.
I unfolded a cilinder/ring, and measured its area (cm²) with the tekst tool, with hidden lines turned off in view. (bottom strip of fig 1)
The strip at the top drawn with the rectangle tool shows the correct area.
although the face, when selected looks undivided, the square cm² turn out to be only for a part of the ring.(fig 2)
I notest, that drawn with the rectangle tool, entity-info identify's the rectangle as a face, and the unfolded rectangle as a surface.
fig 1
fig 2
test.skp
"History is written by the winners"
Bep
Postby david_h » Wed Aug 28, 2019 10:35 pm
So I have a question. . .and this is coming from a "Top Sketchucator"
(try and contain your laughter at least till I pose the question :mrgreen: )
i am trying to import a collection of materials from a previous version of SU and I can't get those to stay put in my materials pallet. Each time I open us SU I have to reload them.
What am I doing wrong? Needless to say, I don't do this a lot. ;)
david_h
Top SketchUcator
Postby Dave R » Wed Aug 28, 2019 10:38 pm
David, what operating system? What SketchUp version?
Is this a collection of materials in a folder?
Global Moderator
Postby TIG » Wed Aug 28, 2019 10:45 pm
From the 'palette' phrasing I guess you are on a MAC ?
No matter, when you import a collection into a model those collection-materials are available in that model.
When you open a new model [or an older one] those collection-materials are not there - why would they be ?
If you want the material-collection to be available in all new models, then open an empty new model from your template, add the collection-materials, then save the model as a template - overwriting your usual template, OR making a new template, and setting that as your default-template.
Now all new models will have those collection-materials associated with it ?
You should also be able to associate the collection with existing models ?
Global Moderator
Postby david_h » Wed Aug 28, 2019 10:51 pm
Thank you my Brethren.
I am on 2019, Win 10.
To TIG's point, I think i need to load these into the template.
thx,
D
david_h
Top SketchUcator
PreviousNext
Return to SketchUp Pro & Make Discussions
Users browsing this forum: No registered users and 6 guests
