General discussion related to SketchUp. No off topic threads please.
by Jeff Hammond » Mon Apr 23, 2012 4:51 am
[mac only duh but still worth pointing out] export a colloda version of your model to your desktop (or wherever) select the .dae push the space bar (which will bring up a quicklook panel) orbit/pan etc or, click on the 'open in preview' button via the quicklook panel.. preview can go full screen on lion.. looks super sweet seeing your model 100% full screen with not even a hint of a menu bar or anything else.. this could be a great way to show/present models on your laptop with barely any effort.. i don't think you can zoom though [EDIT] -- here's an example of a model being viewed full screen (well, downsized for this forum but…).. screen 2012-04-24 at 4.34.38 PM.jpg
dotdotdot
Jeff Hammond
- Global Moderator
- Operating system: Mac
- SketchUp version: 8
- License type: Pro
- SketchUp use: architecture
- Level of SketchUp: Advanced
by jgb » Mon Apr 23, 2012 3:18 pm
TIG wrote:Putting these numbers 'first' IS only necessary... IF you have set shortcuts that clash with those characters. It's recommend that you avoid 'raw' shortcuts of numerals / X * S AND 0-9 - . , ; [ and <. Then the position of that 'modifier' character becomes unimportant. You are ready prevented form specifying 'raw' Ctrl/Shift/Alt key presses; and 'Tab' is flaky anyway - help yourself... However, the use of " ' m c i f etc are all OK to use as shortcuts, because these will always occur after numerals in any dimensional inputs anyway. Also remember - many 3rd party tools now use the four 'raw' arrow-keys [for example to 'nudge' textures], so it's also best to avoid shortcutting to those.
Good point; I never even thought about that. In fact in reviewing what you said, the 'S' key is the only one of those mentioned I use as a direct shortcut (Solid Inspector), and that is the only one I recall having to put the ### first. I use the 'X' as well, but right now, can't remember what for....
__________________ jgb
jgb
- Name: Joel Berson
- Operating system: Windows
- License type: Free/Make
- SketchUp use: engineering and mechanical design
by seven.sides » Tue Apr 24, 2012 4:51 pm
Don't know if this one has been mentioned at all, but I frequently hit the window maximise button by accident when intending to mininimise or close a file. If you have many toolbars open and laid out how you want them, when you re-maximise the window, they will not return to the positions you had set up. Frustrating!
The solution is once you have your toolbars how you like them, go to "view" menu, then "toolbars", scroll down until you see "save toolbar positions", click this. Once this is done, you can return to the same menu at any time to click "restore toolbar positions" if they become disordered.
Tip. remember to resave your toolbar positions if you change the layout / get new plugins.
seven.sides
by jgb » Tue Apr 24, 2012 8:32 pm
seven.sides wrote:The solution is once you have your toolbars how you like them, go to "view" menu, then "toolbars", scroll down until you see "save toolbar positions", click this. Once this is done, you can return to the same menu at any time to click "restore toolbar positions" if they become disordered.
Alas, it does not always work, especially after an SU crash that blows your toolboxes out of the water. While I have not had it happen (a total blowup) since the SU8 update, it did a few times before. So, after I do a major toolbar location revamp (usually after a pluggin that has an extensive toolbar layout) I commit to paper the locations. And I hit "save toolbars" on occasion, just in case, even with no changes.
jgb
- Name: Joel Berson
by Jeff Hammond » Fri Apr 27, 2012 12:58 am
in another thread, Jean Lemire wrote:For both scenes, I unchecked the memorisation of the camera location to avoid loosing a carefully orbited, panned and zoomed view when switching from one mode to another.
Just ideas.
doh! didn't realize you could do that.. .
dotdotdot
Jeff Hammond
- Global Moderator
- License type: Pro
by Pilou » Mon Apr 30, 2012 3:03 am
 Expand revelation! I had always believed that was reserved to Mac users to have pile of windows like that! So never try to click on the blue title and have full windows if needed by Right Click on the object or moving from the Menu! expand.jpg
Pilou
- Top SketchUcator
- SketchUp version: 6
- SketchUp use: hobby
by andybot » Wed May 09, 2012 11:33 pm
Yay! I came upon a huge doh moment, thanks to Taff (he who "makes you think") from this recent thread which sent me to this thread which links to a sketchup sage articleand long story short, I found that by holding down the "primary mouse button" while using the rotate (protractor) tool, it will inference to the perpendicular of a line. Simply Brilliant!! I've always wondered how to rotate about an axis without constructing a bunch of lines and faces
andybot
- Premium Member
- Name: Andy
by TaffGoch » Wed May 09, 2012 11:49 pm
andybot wrote:Yay! I came upon a huge doh moment, thanks to Taff ... ...and long story short, I found that by holding down the "primary mouse button" while using the rotate (protractor) tool, it will inference to the perpendicular of a line. Simply Brilliant!! I've always wondered how to rotate about an axis without constructing a bunch of lines and faces
My primary tip, for any beginning (and, it seems, experienced) SketchUp user! -Taff
"Information is not knowledge." -- Albert Einstein
TaffGoch
by andybot » Wed May 09, 2012 11:59 pm
TaffGoch wrote:My primary tip, for any beginning (and, it seems, experienced) SketchUp user!
-Taff
Well, this is certainly an example of the dangers of "self-taught"  One can tend to skip over some basic stuff every now and then...
andybot
- Premium Member
- Name: Andy
by Jeff Hammond » Thu May 10, 2012 12:06 am
andybot wrote:I found that by holding down the "primary mouse button" while using the rotate (protractor) tool, it will inference to the perpendicular of a line.
[fwiw- it will also let you orient the protractor to a major axis without orbiting the view etc.. fwiw2.. sort of an ongoing request by people to give this functionality to the circle tool]
dotdotdot
Jeff Hammond
- Global Moderator
- License type: Pro
by jgb » Thu May 10, 2012 8:44 pm
andybot wrote:I found that by holding down the "primary mouse button" while using the rotate (protractor) tool, it will inference to the perpendicular of a line. Simply Brilliant!! I've always wondered how to rotate about an axis without constructing a bunch of lines and faces
Well shiver me boots. I often need to construct a face/shape/line perpendicular to a non-axis aligned line, and went through all sorts of temp construction to do it. even resorted to "Pipe-along-path" for some. So now, for those who may not see the power in this "duh" moment, is how in just a few mouse clicks, make a face perpendicular to any line orientation. Put the PROTRACTOR tool somewhere on, or even at the endpoint of the line and hold down the primary mouse button. When the protractor aligns with the perp to that line, release the button, select any angle, click and select any angle away, say 90 deg and click again. Now you have 1 guide line perpendicular to the line at some random angle. Do this again, but put the protractor ON the intersection of the guide and your line, and set another guide line at some angle away from the first guide line, say 90 deg away. You now have 2 guide lines perp to your line. Pencil tool 4 lines from any point on each guide, and a face will form that is perpendicular to the line. Use that face as your construction canvas. Bonus, the face is NOT intersected to the line so the whole line is still intact, until you intersect them.
jgb
- Name: Joel Berson
by rv1974 » Sun May 13, 2012 8:37 am
One can assign shortcuts to the 'Numpad' keys! A huge gain, especially for lefties. Doh!
rv1974
- Name: rv1974
- License type: Pro
by ArCAD-UK » Wed May 30, 2012 10:51 am
Just discovered in Layout 3 that if you select a block of text and right click (PC) there is a "Size to Fit" option which retains the text block width but extends the box height to show all the text. The amount of time I've spent manually adjusting my text boxes when the contents have been edited...
ArCAD-UK
- Name: Trevor B.
- SketchUp version: 2013
- License type: Pro
by rv1974 » Wed May 30, 2012 2:43 pm
The 'Lock\unlock aspect ratio' at material edit drove me crazy for years. Clicking it wont change visually its state (stupid bug!). To see it changed one should move the cursor off the button.
rv1974
- Name: rv1974
- License type: Pro
by iecovert » Mon Jun 11, 2012 2:07 pm
ALL toolbars can be mounted on the top OR the side! Not just the SU tools.
I've got an increasing number of toolbars mounted up top since that's the way they first show up when a plugin is installed. The decreasing workspace was becoming an issue. The original SU toolbars mount vertically, so I set out to figure out how I could make the new Ruby and plugin toolbars mount vertically too. That seems to make more sense with a widescreen monitor. Spent several hours searching through the forums, help topics, and eventually digging into various Ruby scripts trying to figure it out over the past two weeks. Then last night I was moving a floating toolbar window and grabbed it a little to close to the edge and... it "stretched" out vertically. Finally...
iecovert
- Name: Ben
by Aerilius » Sun Jul 01, 2012 8:57 pm
(This belongs probably also into the developers forums:) - Code: Select all
window.onerror = function(errorMsg, url, lineNumber){ return true }
This catches WebDialog script error popups (should they still sometimes occur after thorough testing)! Why didn't I find that before? Note: It needs to be assigned directly to window and not attached like $(window).bind("error", function(){}).
Aerilius
- Top SketchUcator
- Name: Aerilius
by Gaieus » Sun Jul 01, 2012 9:06 pm
Interesting. I do not have that "duh moment" reading this.
- Administrator
- Name: Csaba Pozsárkó
- License type: Pro
- SketchUp use: historical reconstruction
by Jeff Hammond » Sat Jul 07, 2012 2:19 pm
Gaieus wrote:Interesting. I do not have that "duh moment" reading this.
same here… more like an "uhhhhh  moment"
dotdotdot
Jeff Hammond
- Global Moderator
- License type: Pro
by Ken » Mon Jul 09, 2012 2:09 am
I guess I could call this "The Well I'll be Darn Thread". I have used Sketchup since V 4. And I know that the text tool will give me info on geometry. Like length, area, but today, surprise, I used the text tool on the apex of an angle and I got the following, the degrees of the angle in the text box. Never saw that before, and I would have an illustration to show you if I could get the text tool to do it again.
Ken
Government rushes to help the irresponsible and does little for the responsible.
Ken
- Premium Member
- License type: Pro
by Gaieus » Thu Jul 12, 2012 10:21 am
I was reading a topic and realized that I did not understand a word. Then looked up and also realized I was in the Developers Forum.
- Administrator
- License type: Pro
by thomthom » Thu Jul 12, 2012 11:38 am
Gaieus wrote:I was reading a topic and realized that I did not understand a word. Then looked up and also realized I was in the Developers Forum.
- Code: Select all
0101011101101000011000010111010000101100001000000111100101101111011101010010000001100100011011110010000001101110011011110111010000100000011101010110111001100100011001010111001001110011011101000110000101101110011001000010000001100010011010010110111001100001011100100111100100111111
- Global Moderator
- Name: Thomas Thomassen
- License type: Pro
by TIG » Thu Jul 12, 2012 12:22 pm
Didn't you mean - Code: Select all
010110010110111101110101001000000110010001101111001000000110111001101111011101000010000001110101011011100110010001100101011100100111001101110100011000010110111001100100001000000110001001101001011011100110000101110010011110010010000000100001
- Global Moderator
- Name: TIG
- License type: Pro
by Rich O Brien » Thu Jul 12, 2012 12:42 pm
- Code: Select all
01101000 01101111 01110111 00100000 01110010 01110101 01100100 01100101 00100001
Rich O Brien
- Administrator
- Name: Rich O'Brien
- License type: Pro
by TIG » Thu Jul 12, 2012 3:17 pm
It wasn't... but - Code: Select all
0100011001100101011000110110101100100000011010010111001100100000011100100111010101100100011001010010000000100001
- Global Moderator
- Name: TIG
- License type: Pro
by mrossk » Thu Jul 12, 2012 3:51 pm
I think I got geek all over me
mrossk
- Name: Michael
- SketchUp version: 7
- SketchUp use: woodworking
by Brodie » Thu Aug 02, 2012 1:50 am
Found a cool one today.
Copy a line over and type 6" to set the distance. Then type *10 to array it 10 times.
What I already knew was that you can type *8 or *4 or whatever to adjust the number of arrayed items.
However I just found out that if you then type 3" or 10" it will keep your array but adjust the spacing. Pretty sweet!
-Brodie
Hardware: Intel i7 980x 3.33 Ghz 6-Core Processor nVidia Quadro FX 3700 512Mb, 18.0 G RAM Software: Maxwell 2.5, SketchUp 8, 3ds Max 2011, Vray, Adobe CS5, AutoCAD 2007, Windows 7 64-bit
Brodie
- Top SketchUcator
by thomthom » Thu Aug 02, 2012 8:36 am
Brodie wrote:Found a cool one today.
However I just found out that if you type 3" or 10" it will keep your array but adjust the spacing. Pretty sweet!
-Brodie Duh!That is sweet! The manual doesn't even mention this! http://support.google.com/sketchup/bin/ ... swer=94863
- Global Moderator
- License type: Pro
by Heaps » Thu Aug 02, 2012 12:35 pm
It even works with circular arrays - just type in the angle in degrees
Heaps
by broomstick » Sat Aug 04, 2012 1:48 pm
-Brodie
This, sir, just made my day!
broomstick
Return to SketchUp Discussions
