General discussion related to SketchUp. No off topic threads please.
by jgb » Sun Mar 25, 2012 5:03 pm
Another thing with Follow-Me I discovered a while back (and reported) is when you are defining a path that has curves, place the template face somewhere on a straight portion of any line segment, NOT at an endpoint. If follow-me starts on an endpoint, the face template follows one of the subtended angles and royally screws up at the end, with an end face out of alignment. This is especially a major factor with closed loops. However, if started on a straight section, it will end perpendicular to the last line of the path, and if the path is a closed loop, it will join properly.
__________________ jgb
jgb
- Name: Joel Berson
- Operating system: Windows
- SketchUp version: 8
- License type: Free
- SketchUp use: engineering and mechanical design
by Pilou » Sun Mar 25, 2012 5:07 pm
Useful to know!
Pilou
- Top SketchUcator
- SketchUp version: 6
- SketchUp use: hobby
- Level of SketchUp: Advanced
by broomstick » Thu Mar 29, 2012 6:59 pm
I've seen this pointed out before, but I just discovered that while orbiting with the middle mouse pressed, if you press the left button, orbit becomes pan. It's a useful way to orbit/pan without using two hands
broomstick
by Pilou » Thu Mar 29, 2012 9:40 pm
Mini Doh  (due forgotten function)  + Alt gives you the possibility to Move a segment escaping at the X Y plan
Pilou
- Top SketchUcator
by thomthom » Thu Mar 29, 2012 10:41 pm
broomstick wrote:I've seen this pointed out before, but I just discovered that while orbiting with the middle mouse pressed, if you press the left button, orbit becomes pan.
!!!  OMF-DUH!!!
- Global Moderator
- Name: thomthom
- License type: Pro
- SketchUp use: architecture
by thomthom » Thu Mar 29, 2012 10:42 pm
A bit awkward though, as I use my index finger usually to press the middle mouse button, so I need to shift to my middle finger to free up my index for the left mouse button. ...which it was the right button that did that...
- Global Moderator
- Name: thomthom
- License type: Pro
by Gaieus » Fri Mar 30, 2012 2:58 pm
thomthom wrote:A bit awkward though, as I use my index finger usually to press the middle mouse button, so I need to shift to my middle finger to free up my index for the left mouse button. ...which it was the right button that did that...
Ditto. I have known this "feature" but could never adapt myself to it.
- Administrator
- Name: Csaba Pozsárkó
- License type: Pro
- SketchUp use: historical reconstruction
by Pilou » Fri Mar 30, 2012 3:19 pm
That is very curious, because with the medium you can rotate many more the Mouse wheel than with index! So more speedy scolling! For the simple reason that the Medium is biggest than the index!  So the medium is always on the whell, so click it is a formality! Try it!
Pilou
- Top SketchUcator
by jgb » Fri Mar 30, 2012 4:04 pm
Pilou wrote:I use my index finger usually to press the middle mouse button
I have always used my mid finger on the wheel, with index on the left button. I also move my mid to the right button when needed as the ring finger has less control (which is why it is the "ring" finger  ). It shouldn't take long to adjust to that finger position. And now I know why my "orbiting" suddenly goes into "panning" when my index finger twitches downward sometimes. Now that I know, I can exploit that feature. Thank you Broomstick. And Pilou, I fail to see what you mean with Move+Alt.  Could you please explain a bit more?
jgb
- Name: Joel Berson
by Pilou » Fri Mar 30, 2012 4:19 pm
Is that more clear ?  Without Alt Z axis is locked! You can make some prisms or no coplanar faces with Move + Alt!  The Z axis become free with Move + Alt  Movetool.jpg
Pilou
- Top SketchUcator
by Jean Lemire » Fri Mar 30, 2012 4:24 pm
Hi Pilou, hi folks.
Yes, pressing the ALT key enables Autofold.
Just ideas.
Jean (Johnny) Lemire from Richelieu, Quebec, Canada.
Jean Lemire
- Global Moderator
- Name: Jean Lemire
- License type: Pro
by Gaieus » Fri Mar 30, 2012 4:51 pm
- Administrator
- License type: Pro
by thomthom » Fri Mar 30, 2012 5:09 pm
I wish there was an option to make SketchUp Smooth+Soft auto-folded edges.
- Global Moderator
- Name: thomthom
- License type: Pro
by Jeff Hammond » Fri Mar 30, 2012 5:13 pm
I've been harping on this for years now but I don't think anyone ever tries it.. oh well
orbit with a thumb button (if your mouse has one).. not only is it more comfortable, it also gets rid of the double duty zoom/orbit mmb... AND- makes panning with the LMB much easier.
dotdotdot
Jeff Hammond
- Global Moderator
- Operating system: Mac
- License type: Pro
by thomthom » Fri Mar 30, 2012 5:18 pm
Thumb buttons are Copy, Paste ...
- Global Moderator
- Name: thomthom
- License type: Pro
by jgb » Sat Mar 31, 2012 5:52 pm
Read it, tried it and I still don't see any advantage. If I want to go Z (blue) I press the UP arrow and it seems to do the same as the autofold, but with exact axis control.  It seems to me that autofold may hold an advantage if we had true 3D screens, but mine is standard 2D, and I cannot control, with any precision, where my object is moving to.
jgb
- Name: Joel Berson
by Jeff Hammond » Sat Mar 31, 2012 6:40 pm
jgb wrote:Read it, tried it and I still don't see any advantage. If I want to go Z (blue) I press the UP arrow and it seems to do the same as the autofold, but with exact axis control.  It seems to me that autofold may hold an advantage if we had true 3D screens, but mine is standard 2D, and I cannot control, with any precision, where my object is moving to.
using the arrow key is the same thing.. you're giving sketchup permission to break a plane(s) into multiple planes.. that's what autofolding means (in sketchup speak).. [and moving along the Z isn't always what's wanted.. hence the cmmd/alt key] now if only follow-me had an autofold option.. we'd then be able to, say, extrude around a helix without the twisting.. (notice if you try that now, sketchup prefers to keep planes in tact as opposed to folding them which is required for a non-twisting extrusion)
dotdotdot
Jeff Hammond
- Global Moderator
- License type: Pro
by TIG » Sat Mar 31, 2012 6:44 pm
That's where FollowMeAndKeep steps in... No twisting ! Also 'EEbyLathe' sorts the FollowMe around and Arc issues too...
- Global Moderator
- Name: TIG
- License type: Pro
by Jeff Hammond » Sat Mar 31, 2012 7:04 pm
TIG wrote:That's where FollowMeAndKeep steps in... No twisting ! Also 'EEbyLathe' sorts the FollowMe around and Arc issues too...
right.. i was just trying to point out a case where autofolding doesn't (and can't) happen so that jgb understands when/where it's needed.. maybe the follow me example just confuses the matter even more unless you already understand the inherent problems of that tool.. ??
dotdotdot
Jeff Hammond
- Global Moderator
- License type: Pro
by brookefox » Sun Apr 01, 2012 12:36 am
I refuse to apologize for being ignorant... I couldn't figure out for the life of me why when twisting with fredo scale, etc., I got nothing much. I had neglected to learn about auto-slicing in the parameters settings menus, or of enabling it with F4. I thought that some form of slicing had to occur, and tried slicing before executing and saw that worked as I thought the routine was supposed to work. In my defense, since I seem to need some, I think it should be more prominently mentioned. Or did I miss it?
Please, register (free) to access all the attachments on the forums. ~ Brooke
brookefox
- Name: Brooke
by Gaieus » Sun Apr 01, 2012 8:42 am
jgb wrote:Read it, tried it and I still don't see any advantage.  ...
Autofold (as the name implies) is mostly an automatic feature of SU when you force it not to maintain co-planar geometry. But you need to force it somehow. In your case, by pressing the up/down arrow. Some other cases (when axis alignment is not that obvious), you press the Alt key letting SU know that now you do not mind if it breaks a face or not. This is just like inferencing: you can always "encourage" SU to infer to certain things like parallel / perpendicular to something instead of axes etc.
- Administrator
- License type: Pro
by jgb » Sun Apr 01, 2012 4:50 pm
I C
jgb
- Name: Joel Berson
by ArCAD-UK » Tue Apr 03, 2012 9:52 am
I hadn't realised until recently that if you set Model Info>Components>Fade rest of model to hide you can still edit a group/component, triple click to select all faces and then (rt-clk) "intersect with model" which you can then edit as required. In some ways I prefer this over solid ops as it avoids creating a new group on layer zero  .
ArCAD-UK
- Name: Trevor B.
by jgb » Tue Apr 03, 2012 3:00 pm
ArCAD-UK wrote:I hadn't realised until recently that if you set Model Info>Components>Fade rest of model to hide you can still edit a group/component, triple click to select all faces and then (rt-clk) "intersect with model" which you can then edit as required. In some ways I prefer this over solid ops as it avoids creating a new group on layer zero  .
A cupala tips on this..... 1) Use layers as well for each group/comp that you are working on, even if you assign them to temp layers. Assign the temp layer ONLY to the comp/group envelope, NOT to the entities inside which best remain on layer0. Intersect with model intersects with visible layers (on) even if they are "hidden" within the edit mode. That way you avoid unwanted intersections with other groups/comps by simply turning ON only the layer(s) as appropriate. You can then turn on/off layers while in edit mode to better see what you are doing. 2) If there is too much stuff around the group/comp you are working on, then make it a comp (even if temporarily) and pull a copy of it into free space. Do the edits on the copy, then delete it when finished. You can also pull copies of stuff surrounding the prime comp over to the working copy as needed for edit or intersect reference. 3) You can also hide (in edit mode) other copies of the same comp so they do not distract when editing. Sometimes you may have multiple copies quite close together and you cannot see what you are doing. 4) If you have a comp that intersects with stuff on multiple faces that are not involved with the actual "intersect w/Model" then only select the involved faces, rather than a triple click. And that is faster as well.
jgb
- Name: Joel Berson
by ArCAD-UK » Tue Apr 03, 2012 5:58 pm
Some good tips there Joel!
ArCAD-UK
- Name: Trevor B.
by thomthom » Sun Apr 22, 2012 12:15 pm
Really Pilou - a veteran like you didn't know that? It also works with /12 and 12/.
- Global Moderator
- Name: thomthom
- License type: Pro
by Pilou » Sun Apr 22, 2012 2:11 pm
I allways use the "*" against the "x" Because I have a numeric keyboard so no movement and can be pressed with the same hand!
Pilou
- Top SketchUcator
by jgb » Sun Apr 22, 2012 8:24 pm
thomthom wrote:Really Pilou - a veteran like you didn't know that? It also works with /12 and 12/.
In my experience you should put the numbers before the function. I have had problems with defining arc/circle segments and rotation multiples putting the function 'S' or 'X' first. So to be consistent, and remember it, for all these moves, rotates, arc and circles I put the numbers first.
jgb
- Name: Joel Berson
by TIG » Sun Apr 22, 2012 10:20 pm
Putting these numbers 'first' IS only necessary... IF you have set shortcuts that clash with those characters. It's recommend that you avoid 'raw' shortcuts of numerals / X * S AND 0-9 - . , ; [ and <. Then the position of that 'modifier' character becomes unimportant. You are ready prevented form specifying 'raw' Ctrl/Shift/Alt key presses; and 'Tab' is flaky anyway - help yourself... However, the use of " ' m c i f etc are all OK to use as shortcuts, because these will always occur after numerals in any dimensional inputs anyway. Also remember - many 3rd party tools now use the four 'raw' arrow-keys [for example to 'nudge' textures], so it's also best to avoid shortcutting to those.
- Global Moderator
- Name: TIG
- License type: Pro
Not a Premium Member yet? Check out the great time-limited deal we are offering.
- Robot
Return to SketchUp Discussions
