The "Duh!" thread (aka the Doh! thread)
General discussion related to SketchUp Pro and Make
Re: The "Duh!" thread (aka the Doh! thread)
Postby ken » Sun Jan 22, 2012 7:57 pm
Well I can thank DaveR for the "Duh". In another thread he convinced me that using components was the only way to model. So I made a series of components that I wanted to keep in my template file. So modeling away, I had a nice bunch of components for future use.
So I cleaned up the screen because I wanted a clean screen when I open the template file. Than I purged the model components because I didn't want any components that I didn't need in the template and saved the file as template to use.
So, need I say more. The template had no components. "Duh".
Thanks Dave, you did me a favor, I just forgot how to use Sketchup.
ken
Premium Member
Premium Member
Postby cotty » Fri Jan 27, 2012 9:00 am
My Duh! of the day was in this thread: http://forums.sketchucation.com/viewtopic.php?f=22&t=8046
- Use the eraser tool to select some edges
- Don't release the left mouse button
- Click the spacebar
- Release the left mouse button and the selection still remains without deletion
cotty
Top SketchUcator
Postby Gaieus » Fri Jan 27, 2012 12:06 pm
That does not really deserve a "Duh". Although it is obviously an extremely nifty trick, that is not the intended use of the autoselect function of the Eraser tool.
So I would have not been ashamed if I had not known about it yet (and I also learned it from the forums of course)
-1
Postby Charlie__V » Fri Feb 03, 2012 5:06 am
Not sure if this qualify's as a Duh!
& perhaps mentioned before..........though I do not recall seeing it.
I have frequently experienced a "slow save" on certain models and not so much on others.
While working my current model with lots & lots of bolts/nuts/washers..it occured to me that the delay in save may be tied to the "redefine thumbnail on save" option in...........Model info>>>>>File>>>>>Redefine Thumbnail on save.
Sure enough.......un-ticking the "redefine thumbnail on save" resulted in a 10x faster "save" than with this selected.
For me the thumbnail being current is no concern......I prefer the quick "save"
Best,
Charlie
PS............wonder if this contributes to the Bugsplat on save/close??
Charlie__V
Postby Wo3Dan » Mon Feb 13, 2012 10:51 pm
Thanks Gaieus, you've sent me here because I've up until now completely missed the "always face camera" component method you provided here:
viewtopic.php?f=15&t=43251
:shock:
Wo3Dan
Top SketchUcator
Postby Gaieus » Mon Feb 13, 2012 11:34 pm
That was actually a semi-duh moment to me as well. I had not known it was going to work but had to try, you have to admit. :)
Postby oganocali » Thu Mar 08, 2012 12:47 pm
This thread is one of my favorites, I use it as a guide for really neat tricks which most users will eventually need to find out, except it is a bit disorganized. I think some sort of index would be useful here. I may be setting up myself unwittingly for my d'oh moment like the use of advanced search inside a topic or something.
cheers
oganocali
Postby david_h » Fri Mar 09, 2012 8:50 pm
Organization of the D'uh Thread would seem to me to be an Oxymoron. (for me its more Moron than Oxi . . ) but I digress. . .
the whole purpose of the thread is for people to post whatever epiphany they have or discovery they make when it occurs. Ya never know what you're gonna get. . . That is what makes the the SU Forum so much like a box of um . .. um . .. . what is the expression???? :mrgreen:
If I make it look easy. . .then it probably is.
david_h
Top SketchUcator
Postby oganocali » Sat Mar 10, 2012 10:45 am
I totally agree with you on the spirit of this thread. It is just that finding one post in 20+ page (considering forum pages can be quite long) thread is not easy. I usually remember there was a trick as someone's doh! moment to do what I want, I just can not remember who or where the trick was.
oganocali
Postby derei » Sat Mar 10, 2012 11:24 am
I totally agree with the fact that Duh moments get lost between posts and is really hard to follow them now.
DESIGNER AND ARTIST DEREI.UK
derei
Postby Gaieus » Sat Mar 10, 2012 1:08 pm
oganocali wrote:I usually remember there was a trick as someone's doh! moment to do what I want, I just can not remember who or where the trick was.
I had one of those DUH moments regarding the forums as well... :roll:
Postby derei » Sat Mar 10, 2012 1:13 pm
Usually searching works when you know exactly what you want... if I want to find "something that was somehow... I don't know exactly, but I can recognize if I see it", I'm sure that search box won't help :mrgreen:
derei
Postby pilou » Sat Mar 24, 2012 9:31 pm
Maybe this is yet known but I just discover that today :oops: (Thx Chri)
With the follow-me, no need to select only the path, before call the Follow-me!
Click the surface is sufficient ! :shock:
I made Double clicks on the surface then Shift + Ctrl for deselect it for have only the path :mrgreen:
(Double click Without deselection works also but... :oops:
Here just 3 simple clicks :fro:
Speedy Galerie
Top SketchUcator
Postby thomthom » Sun Mar 25, 2012 2:32 am
That's a new Duh! moment for me!!
PluginStore Author
PluginStore Author
Postby Gaieus » Sun Mar 25, 2012 9:35 am
Is it? :)
Interesting although admittedly I also have duh moments on trivia sometimes.
Note however that is there is a soften edge (say a diagonal) in the face, the follow me will not go completely around - not even when simply double clicking. In this case Pilou's "original" method: Double clicking then deselecting the inner (sur)face will do the job though.
So basically it only woks with single faces. Not even with coplanar but subdivided faces.
Postby jgb » Sun Mar 25, 2012 5:03 pm
Another thing with Follow-Me I discovered a while back (and reported) is when you are defining a path that has curves, place the template face somewhere on a straight portion of any line segment, NOT at an endpoint. :o
If follow-me starts on an endpoint, the face template follows one of the subtended angles and royally screws up at the end, with an end face out of alignment. This is especially a major factor with closed loops. :thumbd:
However, if started on a straight section, it will end perpendicular to the last line of the path, and if the path is a closed loop, it will join properly. :thumb:
__________________
jgb
jgb
Postby pilou » Sun Mar 25, 2012 5:07 pm
Useful to know! :thumb:
Speedy Galerie
Top SketchUcator
Postby broomstick » Thu Mar 29, 2012 6:59 pm
I've seen this pointed out before, but I just discovered that while orbiting with the middle mouse pressed, if you press the left button, orbit becomes pan.
It's a useful way to orbit/pan without using two hands :)
broomstick
Postby pilou » Thu Mar 29, 2012 9:40 pm
Mini Doh :oops: (due forgotten function) :roll:
:move: + Alt gives you the possibility to Move a segment escaping at the X Y plan ;)
Speedy Galerie
Top SketchUcator
Postby thomthom » Thu Mar 29, 2012 10:41 pm
broomstick wrote:I've seen this pointed out before, but I just discovered that while orbiting with the middle mouse pressed, if you press the left button, orbit becomes pan.
!!! :shock: OMF-DUH!!!
PluginStore Author
PluginStore Author
Postby thomthom » Thu Mar 29, 2012 10:42 pm
A bit awkward though, as I use my index finger usually to press the middle mouse button, so I need to shift to my middle finger to free up my index for the left mouse button. ...which it was the right button that did that...
PluginStore Author
PluginStore Author
Postby Gaieus » Fri Mar 30, 2012 2:58 pm
thomthom wrote:A bit awkward though, as I use my index finger usually to press the middle mouse button, so I need to shift to my middle finger to free up my index for the left mouse button. ...which it was the right button that did that...
Ditto. I have known this "feature" but could never adapt myself to it.
Postby pilou » Fri Mar 30, 2012 3:19 pm
That is very curious, because with the medium you can rotate many more the Mouse wheel than with index! :shock:
So more speedy scolling! :fro:
For the simple reason that the Medium is biggest than the index! :enlight:
So the medium is always on the whell, so click it is a formality! :)
Try it! ;)
Speedy Galerie
Top SketchUcator
Postby jgb » Fri Mar 30, 2012 4:04 pm
Try it! ;)
I have always used my mid finger on the wheel, with index on the left button. I also move my mid to the right button when needed as the ring finger has less control (which is why it is the "ring" finger :lol: ).
It shouldn't take long to adjust to that finger position.
And now I know why my "orbiting" suddenly goes into "panning" when my index finger twitches downward sometimes. Now that I know, I can exploit that feature. Thank you Broomstick.
And Pilou, I fail to see what you mean with Move+Alt. :?: Could you please explain a bit more?
__________________
jgb
jgb
Postby pilou » Fri Mar 30, 2012 4:19 pm
Is that more clear ? :oops:
Without Alt Z axis is locked!
You can make some prisms or no coplanar faces with Move + Alt! ;)
The Z axis become free with Move + Alt :)
Speedy Galerie
Top SketchUcator
Postby Jean Lemire » Fri Mar 30, 2012 4:24 pm
Hi Pilou, hi folks.
Yes, pressing the ALT key enables Autofold.
Just ideas.
Jean (Johnny) Lemire from Richelieu, Quebec, Canada.
Jean Lemire
Global Moderator
Postby Gaieus » Fri Mar 30, 2012 4:51 pm
And here is the autofold description:
http://support.google.com/sketchup/bin/ ... swer=94865
Postby thomthom » Fri Mar 30, 2012 5:09 pm
I wish there was an option to make SketchUp Smooth+Soft auto-folded edges.
PluginStore Author
PluginStore Author
Postby jeff hammond » Fri Mar 30, 2012 5:13 pm
I've been harping on this for years now but I don't think anyone ever tries it.. oh well
orbit with a thumb button (if your mouse has one).. not only is it more comfortable, it also gets rid of the double duty zoom/orbit mmb... AND- makes panning with the LMB much easier.
dotdotdot
jeff hammond
Global Moderator
Postby thomthom » Fri Mar 30, 2012 5:18 pm
Thumb buttons are Copy, Paste ...
PluginStore Author
PluginStore Author
PreviousNext
Return to SketchUp Pro & Make Discussions
Users browsing this forum: oidsystem and 7 guests
