The "Duh!" thread (aka the Doh! thread)
General discussion related to SketchUp Pro and Make
Re: The "Duh!" thread (aka the Doh! thread)
Postby thomthom » Wed Sep 14, 2011 1:03 pm
rv1974 wrote:If Thom is already here..
Only last week I discovered know that double clicking on blue balloons (edge tools-inspect gaps) actually close the gaps.
Great tool!
Ah, yea it's not that obvious - I had further plans for the UI. (also for CleanUp), but they've been down-prioritized.
btw, no need to doubleclick - single click is enough.
PluginStore Author
PluginStore Author
Postby Gaieus » Thu Sep 15, 2011 10:32 pm
Jim wrote:I just learned that Edit > Delete Guides is context-sensitive - it deletes guides all guides starting from the current editing context and deeper, but not from "higher" level contexts. I had always thought it always deleted all guides, everywhere.
Doh. :shock:
rv1974 wrote:Only last week I discovered that double clicking on blue balloons (edge tools-inspect gaps) actually close the gaps.
What???!!! :bounce:
Postby pilou » Wed Oct 12, 2011 10:04 pm
Being able to select only a few edges from a face and offset them instead of the whole face.
Yes but edges must be selected without discontinuity! :oops: :oops: :oops:
Speedy Galerie
Top SketchUcator
Postby boofredlay » Thu Oct 13, 2011 3:16 pm
Something I just learned a couple days ago while studying the Google Earth Modeling videos.
D'oh, never knew that you could make a unique texture from a portion of another!
boofredlay
Global Moderator
Postby pilou » Thu Oct 13, 2011 5:48 pm
Seems only from the V7 and + ;)
Speedy Galerie
Top SketchUcator
Postby Daniel » Sat Nov 05, 2011 7:17 pm
I've always known about hiding geometry by holding the shift key with the eraser, but last week I just noticed the "hidden" check box on the entity info window. :oops:
My avatar is an anachronism.
Daniel
Postby Bob James » Sat Nov 05, 2011 8:31 pm
Never paid any attention to this thread until today :oops:
TIG wrote:.....select all faces with the same material as the one highlighted... then RickW pointed out that it is already a standard built-in tool under Select... :oops:
OMG :shock: I soooo needed this yesterday :knockout:
This thread is one of the greatest tutorials ever made!
Now to Page 1 and read (and write down) all of the golden nuggets in this thread.
Bob James
Premium Member
Premium Member
Postby Jim » Sat Nov 05, 2011 10:40 pm
Bob James wrote:This thread is one of the greatest tutorials ever made!
Yeah, this thread would make a great mini-pub for SCF. I'd probably even buy a tree-ware version as I can't retain online info as well as I can with a good sit with a book.
Jim
Global Moderator
Postby Bob James » Mon Nov 07, 2011 12:45 am
SU Duh.pdf
Compilation of DUHs
This is an unedited regurgitation of all of the DUH items. Some are repeated.
Bob James
Premium Member
Premium Member
Postby pilou » Mon Nov 07, 2011 1:31 am
Cool idea! :fro:
I will translate it when I arrive at this page! :) (in fact a sort of speedy copy / past because ...
I am now at the page 7 on French Section ! :mrgreen:
Speedy Galerie
Top SketchUcator
Postby derei » Mon Nov 07, 2011 8:40 am
What the... :shock:?
6.I could change the radius of a circle that's been extruded - maybe using Scale Tool :?
19. finding that by holding the spacebar down you can control the zoom in so you don't zip past the
object your zooming to
- really ? It doesn't seem to happen anything different when I zoom and keep spacebar pressed.
...and the list can continue.
Maybe those should be verified, or given more detailed explanations. After all, its purpose is to teach the noobs, not to confuse them more :mrgreen:
EDIT:
22. Also, any selection that only contains a single entity (not only a line) cannot be made a
component (or group) this way. If you select a sphere (with a bounding box), there's a single
"surface" selected only and you right click to turn it into a group/component in vain.
- try pressing G or use the Make Component icon ... ;) maybe is not in vain
DESIGNER AND ARTIST DEREI.UK
derei
Postby Gaieus » Mon Nov 07, 2011 9:42 am
dereeei wrote:22. Also, any selection that only contains a single entity (not only a line) cannot be made a
"surface" selected only and you right click to turn it into a group/component in vain. - try pressing G or use the Make Component icon ... maybe is not in vain
That's true - thus the inconsistency. SU should work the same way no matter where we access the same tool.
Postby HFM » Mon Nov 07, 2011 4:22 pm
Found out last week that you can also color lines in your model :shock:
It even works with custom drawing styles :D
HFM
Postby jeff hammond » Mon Nov 07, 2011 5:22 pm
dereeei wrote:What the... :shock:?
you can change the radius via the entity info dialog.. the same way you would change the radius of a circle except that it also works if the circle has been extruded
dotdotdot
jeff hammond
Global Moderator
Postby derei » Mon Nov 07, 2011 5:28 pm
Jeff Hammond wrote:you can change the radius via the entity info dialog.. the same way you would change the radius of a circle except that it also works if the circle has been extruded
Heh, that's cool :D Inattentional blindness is to blame... I've seen that number of segments is grayed-out, and I didn't seen that the radius is fully editable.
derei
Postby pilou » Mon Nov 07, 2011 5:33 pm
you have a crazzy plug about that! ;)
ChrisP_Color_edge By C Plassais :fro:
Speedy Galerie
Top SketchUcator
Postby d12dozr » Mon Nov 07, 2011 7:49 pm
You can use the Move tool on the cardinal points to change the radius of an extruded circle as well
http://goo.gl/f7ooYh
d12dozr
Top SketchUcator
Postby gilles » Tue Nov 08, 2011 11:11 am
Did you know this one?
gilles
Top SketchUcator
Postby derei » Tue Nov 08, 2011 11:14 am
gilles wrote:Did you know this one?
AWESOME !!! :shock: This is something I never would guess. Thank you! ;)
derei
Postby gilles » Tue Nov 08, 2011 11:31 am
works also with polygones.
Rereading the user manuel is fully instructive.
gilles
Top SketchUcator
Postby brandy20 » Tue Nov 08, 2011 11:55 am
:o another one to add yo the list of my uncountables duh! in the last two years...
Another big duh! for me, to realize just yesterday evening of this very instructing topic. Must surf more carefully through this forum. :oops:
brandy20
Postby jeff hammond » Tue Nov 08, 2011 4:41 pm
:shock:
no.. i didn't.
that's pretty sweet.. now, i'm left wondering if i have a use for it :D
dotdotdot
jeff hammond
Global Moderator
Postby dale » Tue Nov 08, 2011 5:26 pm
This one was new to me (Doh)
I was doing a lot of similar push pulls on a model (without joint pushpull), and inadvertently double clicked on the second one, and SketchUp duplicated the depth of the first pushpull.
So i just went along double clicking, and the action repeated itself exactly.
Boy could I ever have used this alot.
dale
Top SketchUcator
Postby TIG » Tue Nov 08, 2011 5:42 pm
Works the same for Offset too - double-click repeats the last used value...
Global Moderator
Postby Rich O Brien » Tue Nov 08, 2011 5:48 pm
Now double click the middle mouse button ;)
Rich O Brien
Administrator
Postby Gaieus » Tue Nov 08, 2011 6:02 pm
But double click on something.
Postby cotty » Wed Nov 09, 2011 9:44 pm
I've learned a lot from this thread and here is my little "Duh!"...
Textures of different (coplanar) faces can be combined (context menu - combine textures (?, don't know the english translation of the menu)) if they are preselected.
Because the inner lines can be deleted, this reduces the file size (e.g. for google earth models).
"Make unique texture" reduces file size too (textures are trimmed).
cotty
Top SketchUcator
Postby Gaieus » Wed Nov 09, 2011 9:57 pm
Yes, especially this second one is extremely important for GE modelling. I think it was introduced in version 7 and was very welcome (although the AA algorithm could be better as the resulting textures are rather bad quality)
Postby Wo3Dan » Wed Nov 09, 2011 10:56 pm
Yes, I knew it worked on arc surfaces.
But I didn't realize that it also works on cilinders (on a cardinal midpoint to resize it) until now.
It even works on a truncated cone's cardinal midpoints "Doh!"
b.t.w. The "arc surface midpoint moving" feature also works with two different arcs, top arc unequals bottom arc. I guess this is similar to being able to resize the truncated cone in "one go".
Wo3Dan
Top SketchUcator
Postby pingo » Thu Nov 17, 2011 10:14 pm
Thank you, Thank you, Thank you!!
It's taken me a few days to read through this thread and practise all the many things I didn't know before. So many helpful tips will surely make my future modelling so much easier!
pingo
PreviousNext
Return to SketchUp Pro & Make Discussions
Users browsing this forum: santos9990 and 8 guests
