SketchUcation Plugin Store
A better offset for non coplanar faces !?  Topic is solved
General discussion related to SketchUp. No off topic threads please.
Postby ely862me » Wed Jun 13, 2012 9:01 pm
Hi there !
I am doing a project and it gets to my nerves !
Is there a way to make an offset that will have the edges placed on the hidden lines ? I did this offset on a bunch of faces and then i tried to push them with JPP, and because of these edges it gives me many errors.
So is there any way to make the offset geometry to have the corners placed on the hidden lines ?
Thanks !
EDIT: I used Tools on surface's for the above picture, and it is not what I need !
Elisei (sketchupper)
____________________________________________________________
Come and See EliseiDesign
User avatar
ely862me
Top SketchUcator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: other
Level of SketchUp: Intermediate
Re: A better offset for no coplanar faces !?
Postby Brodie » Wed Jun 13, 2012 9:08 pm
Hardware: Intel i7 980x 3.33 Ghz 6-Core Processor
nVidia Quadro FX 3700 512Mb, 18.0 G RAM
Software: Maxwell 2.5, SketchUp 8, 3ds Max 2011, Vray, Adobe CS5, AutoCAD 2007, Windows 7 64-bit
User avatar
Brodie
Top SketchUcator
Postby ely862me » Wed Jun 13, 2012 9:19 pm
Sorry I didn't mentioned in the first post, but I use(d) Tools on surface for that ! Unless there is a setting that will keep the corners on the hidden lines , it is not possible to do it with TOS !
Thanks !
User avatar
ely862me
Top SketchUcator
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby Jeff Hammond » Wed Jun 13, 2012 9:36 pm
everything i've tried regarding this type of stuff in sketchup leads me to the conclusion…
you have to do these things manually.. a lot more time consuming but it's the only way to do it right..
sketchup just isn't smart enough to handle it (meaning su is Dumb in that individual edges or curve segments don't pay attention to what the adjacent ones are doing.. it's just a bunch of individual edges/faces instead of a collective unit )
User avatar
Jeff Hammond
Global Moderator
Operating system: Mac
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Postby ely862me » Wed Jun 13, 2012 10:19 pm
:| :x
I wish I would have learned other software !
I already did the entire shell line by line(because the client wanted the net to follow exactly the cad drawings). I am tired of this and I don't know how to finish it ! The purpose of the offset would be to create grooves where the lines are shown now. If you know another faster way, please let me know ! The lattice maker won't do it because it creates lattice on hidden lines too.
These days I realized I use mainly the plugins, otherwise it is not possible to get the job done !
Thanks for the reply !
User avatar
ely862me
Top SketchUcator
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby Rich O Brien » Wed Jun 13, 2012 10:33 pm
Hi Eli,
Does this net overlay match the underlying mesh?
:::Blog:::
I'm a Trimbler now!
User avatar
Rich O Brien
Administrator
SketchUp version: 8
License type: Pro
SketchUp use: engineering and mechanical design
Postby ely862me » Wed Jun 13, 2012 10:40 pm
Rich O Brien wrote:Hi Eli,
Yup, that's the main reason I created it manually to match the grooves, so it will be easier for the next operations !
User avatar
ely862me
Top SketchUcator
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby Rich O Brien » Wed Jun 13, 2012 10:51 pm
Is this going to be printed/rendered?
The reason I ask is that could you make a custom texture that fulfills the effect?
:::Blog:::
I'm a Trimbler now!
User avatar
Rich O Brien
Administrator
SketchUp version: 8
License type: Pro
Postby ely862me » Wed Jun 13, 2012 10:58 pm
I wouldn't pay that much attention to details, unfortunately it has to be 3d printed . Inside the grooves will be placed real ropes to attach the cabin underneath and to give it a real effect .
Thanks and have a lovely day !
PS I am off to bed now(already 01:00 AM here) . I hope to wake up tomorrow with some new solutions(in my mind) :fro: !
User avatar
ely862me
Top SketchUcator
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby Rich O Brien » Wed Jun 13, 2012 11:20 pm
Did you try this in Blender? It has a very good latticing tool but it would mean remodeling.
Or I know Rhino has this also (Jeff may know more on this)?
:::Blog:::
I'm a Trimbler now!
User avatar
Rich O Brien
Administrator
SketchUp version: 8
License type: Pro
Re: A better offset for non coplanar faces !?
Postby ely862me » Thu Jun 14, 2012 1:49 pm
Rich O Brien wrote:Did you try this in Blender? It has a very good latticing tool but it would mean remodeling...
I haven't tried other software yet, and I think I won't do it , at least not for this project !
This morning I woke up with new strength and I started removing the small segments from the offset operation. It took me about 3 hours, but now it is done !
Thanks to all for the comments and ideas !
User avatar
ely862me
Top SketchUcator
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby Jeff Hammond » Thu Jun 14, 2012 6:08 pm
ely862me wrote:This morning I woke up with new strength and I started removing the small segments from the offset operation. It took me about 3 hours, but now it is done !
:thumb: :thumb:
that's pretty much how you have to do it.. ;) sketchup is awesome in many regards but it just can't (automatically) handle this type of stuff properly..
looks good.
User avatar
Jeff Hammond
Global Moderator
SketchUp version: 8
License type: Pro
Postby ely862me » Thu Jun 14, 2012 7:58 pm
Thanks Jeff !
I don't know how ruby works but I thought it will be easy to create a plugin that will search for segments which are smaller than, lets say 1mm and remove those segments and connect the lose end to/with the nearest segment. Will it be possible ?
User avatar
ely862me
Top SketchUcator
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby thomthom » Fri Jun 15, 2012 10:07 am
ely862me wrote:Thanks Jeff !
Edge Tools
viewtopic.php?t=24593
Use the "Inspect and Close Gaps" feature. I use it all the time for cleaning up CAD drawings. It doesn't just connect to closest vertex, but tries to extend line segments to nearest intersection - ensuring straight corners.
hmm... think I forgot to make a video tutorial on that...
User avatar
Global Moderator
Name: Thomas Thomassen
SketchUp version: 2013
License type: Pro
Postby ely862me » Fri Jun 15, 2012 12:24 pm
Your tool is interesting, but it doesn't do the job .
See attached , what I would like it to do is to remove the small segment and move the lose end to the hidden line but at the end of the other segment .
A work around will be to have a plugin removing the small edges(if geometry is not erased/or even then), then to move the loose end near to the other closer segment's end which is placed on the hidden line(better explained to move it to the nearest intersected lines).
Your tool(after I deleted the small segment) just placed the loose end randomly on the hidden line .
STEP 1-Deleting small segments(given range)
STEP 2-Tried to recreate with your plugin,but didn't worked as expected
This should be the correct step 2
Thanks !
User avatar
ely862me
Top SketchUcator
SketchUp version: 8
License type: Pro
SketchUp use: other
Re: A better offset for non coplanar faces !?  Topic is solved
Postby thomthom » Fri Jun 15, 2012 12:49 pm
Ah, I see. No my tool cannot do that. :(
User avatar
Global Moderator
License type: Pro
Postby EarthMover » Fri Jun 15, 2012 1:53 pm
I think best case scenerio would be for Fredo to add a function to Offset on Surface which will perform multiple offsets at once on all "hard" edges in an organic shape. Perhaps a request is in order.
A designer is an emerging synthesis of artist, inventor, mechanic, objective economist and evolutionary strategist. - R. Buckminster Fuller
Some of my 3D crap
User avatar
EarthMover
Top SketchUcator
by Ad Machine » 5 minutes ago
Need Authorised SketchUp Training by experts in various disciplines? Check out our Training details.
Ad Machine
Robot
Return to SketchUp Discussions
Who is online
Users browsing this forum: No registered users and 4 guests
