ability to draw in layout to a scale
Got an idea to improve LayOut?
Postby chadgould » Wed Sep 11, 2013 4:10 pm
I sometimes have the need to add lines and other elements on top of scaled sketchup views (1/4 scale etc) for things like floor elevation lines, column grid lines, even trees and furniture and other scrapbook elements. It would be really nice to be able to draw lines and move elements around in layout at a scale that matches the view of the model without having doing the mathmatical scale conversion to 1:1 in my head.
5
chadgould
Re: ability to draw in layout to a scale
Postby Gmansu8 » Wed Dec 18, 2013 10:13 pm
Yes! Being able to add scaled items (lines, objects, etc.) in Layout as an overlay to an "MView" of a Sketchup model would be helpful. This is already available using the Dimension Tool, simply add the function to the Line, Rectangle, Circle, Arc tools. Both the paper scale and "designated scale" could be shown in the Measurement window.
Let's Do It !!!
Gmansu8
Postby marcdurant » Wed Jan 08, 2014 10:51 pm
We definitely have this one on our list of "often requested" improvements!
6
marcdurant
SketchUp Team
SketchUp Team
Postby ArCAD-UK » Sat Jan 11, 2014 1:24 am
marcdurant wrote:We definitely have this one on our list of "often requested" improvements!
And hopefully DWG export is up there too Marc...
viewtopic.php?f=14&t=55435
ArCAD-UK
Postby idraftnz » Fri Jul 25, 2014 12:56 am
The ability to change the scale of an object imported from Scrap books would be an AWESOME [bold] feature. If it is there already can some let me know ..thanks
idraftnz
Postby deemn » Sun May 17, 2015 7:13 am
also want +1
deemn
Postby mrneene » Tue Jun 07, 2016 9:33 am
Hi there!
I just encountered this problem and found a way you could handle it at the moment (maybe this is already known and nothing new): I write the measurement and divide it then with the scale. For instance if I want to draw 1m in a 1:20 scale in Layout, then I draw the line and type: 1000/20 and hit enter (1000 because of the mm - you can change this in the settings).
I know it might seem like extra work but it after 5 minutes became second nature to. Sure this is no ideal solution and an upcoming Layout feature has to be quite complex, interacting with the viewport and so on...
I'm also not sure if this works with feet, just tried it with metric measurements.
mrneene
Postby baz » Sun Jun 12, 2016 3:25 am
New for me, thanks.
How about scaled rectangles?
I am both an early bird and a night owl, I am some form of permanently energized dragon.
baz
Postby GMthompson » Sat Sep 03, 2016 4:24 pm
I like this idea, i am thinking if you click on your viewport your line tool automatically sets the scale in reference to the viewport
you can learn something everyday by paying attention
GMthompson
Postby gnfreak » Fri Dec 23, 2016 6:05 am
I wish you have tutorial links of that. Please share
gnfreak
Return to LayOut Feature Requests
