Tracing Walls with the Stroke Tool
General discussion related to LayOut
Postby Rose123 » Mon Jul 01, 2019 2:13 am
Hi, I'd like to trace the walls on a top-down view (floor plan) with the stroke tool to make them thicker. But when I do this, the whole plan fills, so I can't see the interior. Is there a setting that I can adjust that will turn this fill off so I can simply trace all the exterior and interior walls?
Rose123
Re: Tracing Walls with the Stroke Tool
Postby pbacot » Mon Jul 01, 2019 6:02 am
What is a stroke tool?
Top SketchUcator
Postby shawb » Mon Jul 01, 2019 8:30 am
I think Rose123 means the 'Lines' tool. Go to the tray panels and select Shape Style & un-check Fill which is above the Stroke option.
shawb
Postby Dave R » Mon Jul 01, 2019 12:32 pm
Turning off Fill in the Shape Style panel, as shawb wrote will prevent the shape from obscuring the plan. There may be an easier way than tracing all the lines, though. Is the plan you are tracing a viewport from a SketchUp model?
Global Moderator
Postby Rose123 » Mon Jul 01, 2019 10:01 pm
Dave, yes, it's a viewport from a SketchUp model. The only other way I can find involves making scenes, copying viewports, lining them up, switching to vector view, and changing line weight in one of the scenes. But that method still doesn't work for me. When I copy viewports, one obscures the other. I can't get the top viewport transparent.
Rose123
Postby Dave R » Mon Jul 01, 2019 10:05 pm
It shouldn't be as difficult as it sounds like it is for you. Could you share the LayOut file with me? I'll see if I can set something up to show you.
Global Moderator
Postby Rose123 » Sat Jul 06, 2019 9:50 pm
Hi Dave, the file is nothing special, it could be any file. I just modeled a simple floor plan to figure the line weights out. I would just like to know the simplest way to make the walls thicker than everything else. So far, tracing the walls in LayOut with the stroke tool is it. I turned off Fill, and it worked. If there's an easier way, please LMK!
Rose123
Postby Dave R » Sat Jul 06, 2019 10:20 pm
Maybe something like this?
Global Moderator
Return to LayOut Discussions
