I am pulling my hair out with this one
If I dimension the lower edge I get one value, if I dimension the upper edge I get a different value,
and both of these values is wildly incorrect as you can see from the SU screen shot
Dimension settings is auto
Layout dimensioning weirdness
• Page 1 of 1
Re: Layout dimensioning weirdnessIt may be the modified scene causing the issue. It's normally not a good idea to modify scenes in LayOut. Can you share the LayOut file so we can see what you've got?
% (THERE'S NO PLACE LIKE) G28 X0.0 Y0.0 Z0.0 M30 %
Re: Layout dimensioning weirdnessHere is the file, thx
Re: Layout dimensioning weirdnessI reset the scene which did not help.
I did some dimensioning in SU and determined that Layout is reporting the diagonal distance!
• Page 1 of 1
