Different colors in layout and sketchup?
General discussion related to LayOut
Postby theo van tango » Sun Sep 09, 2018 5:30 pm
I painted a model in sketchup, after I import it to Layout its colors now has other RGB values
This is huge problem for me since I need to present the correct colors for my clients
see attached pic
Any ideas?
Thanks in advance
Last edited by theo van tango on Mon Sep 10, 2018 10:01 am, edited 1 time in total.
theo van tango
Re: Different colors in layout and sketchup?
Postby Dave R » Sun Sep 09, 2018 7:19 pm
There's no picture to see.
Perhaps you could share a LayOut file that shows this?
Please complete your profile with SketchUp version and operating system. That information can be useful in helping you get issues solved.
User avatar
Global Moderator
Postby Dave R » Tue Sep 11, 2018 1:20 pm
Hows's this? The top is a screen grab from SketchUp while the bottom is from LayOut.
The difference in color is due to the fact that in SketchUp you didn't have a straight on view of the model so the shader that creates the impression of 3D is doing its thing.
You missed a few very important steps.
1. In SketchUp, you need to set up a scene for the view you want to see in LayOut.
2. In LayOut, you need to select that scene for the viewport and make sure you don't do anything to make it show as modified.
You need only select the Scene. Do not adjust the Standard Views in LayOut, don't open the viewport to change the camera position, either. You can adjust the size of the viewport window and adjust the scale of the model without making it modified.
It's also unwise to use Last saved SketchUp view since this is not a v fixed scene.
In your case you have modified the Last saved SketchUp view.
Here's the revised file.
Dansbandet.layout
User avatar
Global Moderator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to LayOut Discussions
Who is online
Visit our sponsors:
