fine objects like bolts and screw threads ..detailing in LO
General discussion related to LayOut
Postby GMthompson » Mon Jul 24, 2017 3:16 pm
I often generate details of connections for structural framing of steel aluminum etc.. i keep libraries of 2d things like bolts, construction teks etc.... very often these things get washed out in layout, layout has a hard time generating such fine lines, outside of wireframe anyways
i have figured out that if you drag/move the group/componenet forward of the other object say 1/2" the line generation gets a lot cleaner or if you make the object with faces and drag it forward it appears like a draw order in other cad programs
does anybody have any tips they use or care to share to display fine objects in a larger models using scales less than an inch
you can learn something everyday by paying attention
GMthompson
Re: fine objects like bolts and screw threads ..detailing in
Postby Box » Mon Jul 24, 2017 3:20 pm
Make 2d scrapbook items that you can use time and time again.
Postby Charlie__V » Mon Jul 24, 2017 4:13 pm
I have done various types of detailing for wood assemblies that require custom metal brackets/plates/etc.
I have used clipping masks to give a "close up" of the part(s).
Maybe that is something you could incorporate? (please see "snapshot" in below .pdf)
Best regards,
Charlie
Charlie__V
Postby bmike » Wed Jul 26, 2017 3:09 am
You can change the line thickness that LO uses to render the window, and you may see exults change if you render in vector or raster. This also can be affected by the style Edge settings in SU.
When I first started doing shop drawings in LO I did a few sheets of typical joinery and changed rendering type, line weights, etc. and built a template with what I liked.
bmike
Postby GMthompson » Tue Aug 01, 2017 1:29 pm
I usually use a line thickness of .1 for these types of details being the display of screws and bolts
i am not big on scrap books for inserting in my eyes cad objects i use them for boiler notes weld symbols section cut lines elevation symbols etc.
GMthompson
Return to LayOut Discussions
Users browsing this forum: Google Bot and 1 guest
