SketchUcation Premium Membership
Styles
Styles
Postby PaulG » Mon May 28, 2012 7:19 pm
I've seen some great looking layout drawings in various threads. But which styles are you guys using? My stuff looks all blocky and pretty horrible.
PaulG
Re: Styles
Postby PaulG » Tue May 29, 2012 9:08 am
I have been messing about and editing the styles and having better results, when I have finished my layout page I get better results changing the raster setting to vector, does this have any negative effects?
PaulG
Re: Styles
Postby ArCAD-UK » Tue May 29, 2012 9:30 am
Vector mode removes some graphic style qualities that can only be represented by a raster image. You may want to look at Hybrid as a compromise.
I prefer vector mode myself as I try to keep my exported file (PDF) sizes to a minimum where possible.
ArCAD-UK
Re: Styles
Postby Dave R » Tue May 29, 2012 10:46 am
It depends upon the project and the audience. For most things I only want black lines on white so vector is the choice. Sometimes I want vector lines but I also want to show materials so Hybrid is appropriate. And other times I want to use a sketchy line style I've made so then I have to stick with Raster. Different options for different applications.
Rendering the lines in Vector takes longer than Raster so I don't switch to Vector or Hybrid until I'm nearly finished with the project.
Inspecting mirrors is a job I could easily see myself doing.
Global Moderator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: woodworking
Level of SketchUp: Advanced
Re: Styles
Postby PaulG » Tue May 29, 2012 12:50 pm
Thanks for the info, most of what I want to do will be black lines on white, it was diagonal lines that wee causing me the biggest issues, especially after export to PDF and when zooming.
Looks like vectors will be the way forward for me.
PaulG
Re: Styles
Postby Sonder » Tue May 29, 2012 5:12 pm
Vector mode is too slow IMHO. Raster always looks better and is much faster. The export quality is far higher than what you are seeing on your screen. If you have to use vector, try to isolate line work so you are not vectoring the entire model. I use both, but only vector line work created by the section tool in Sketchup. It works really well.
Sonder
Re: Styles
Postby Dave R » Tue May 29, 2012 5:29 pm
Vector rendering is indeed slow but I don't get acceptable line work using Raster so Vector it has to be. There are strategies to help reduce the render time but I still find it often gives me a chance to go get something to eat or take a nap.
Global Moderator
SketchUp version: 8
License type: Pro
Re: Styles
Postby Dave R » Sat Jun 02, 2012 2:41 am
FWIW, here is a comparison between Raster and Vector rendering The first PDF is with Output Quality set to Medium. The second at High. And a JPG export of the same thing. The Vector render is by far better.
Global Moderator
SketchUp version: 8
License type: Pro
Re: Styles
Postby pedrinalex » Sun Apr 21, 2013 5:43 am
Hi. Dave
I read your comment.
I can only say, Thank you, is a so little the difference and it is so quick.
Thank you again.
Pedro
MB ASUS M5A97 EVO, AMD FX8120, 32 GB RAM Vengance 1600, 2 Sapphire HD 7770, Crossfire, 4 HD 1 TB c/u
pedrinalex
SketchUp version: 8
License type: Free
SketchUp use: architecture
Need Authorised SketchUp Training by experts in various disciplines? Check out our Training details.
Return to LayOut Discussions
Users browsing this forum: jpalm32, pedrinalex and 1 guest
