SketchUcation Premium Membership
TUT: Creating and Hatching in LayOut
Postby Richard » Thu Jan 06, 2011 5:31 am
From a PM to explain how to create and use hatch patterns in LO I thought I would share this simple process.
I’ll example as a straight square tile hatch.
CREATING HATCH (SEE HATCH.LAYOUT ATTACHED)
1. Open a new LayOut document – Set page size to 200mm x 200mm / no margins / set grid 10mm / grid snap on / object snap off
2. Using the line tool draw a line (1px wide) down one side and copy across each grid interval,
3. Now turn snap to objects on, select all and rotate + crtl to copy rotate through 90deg,
4.Export image as PNG say 500 x 500 pixels to keep it clean, note the larger the image the more LO will struggle when this is imported back in.
USING HATCH (SEE IMAGE BELOW - HATCH USE)
1. Open you working doc (the one you want to apply hatch to) drag and drop the PNG hatch image in,
2. Place it where you wish to hatch and scale appropriately, and push it backward so it is behind the rest of the work,
3. Now draw a line around the perimeter of the area you want hatched (I will assume this is less than the size of the hatch map – more later) and ensure this perimeter closes,
4. Select both this traced perimeter and the hatch map, right click on then and from the context menu select “create clipping mask” – DONE!!!
AREAS TO BE FILLED LARGER THAN THE HATCH MAP
1. DO NOT try to duplicate the hatch map multiple times and then clip with one perimeter clip map! This will work first time yes BUT if you try to edit it later well ALL SHIT will break loose!
2. To fill areas larger than the map, break the area up with multiple copies of the map and multiple clipping masks!!
NOTE
1. If you want a border around the hatched area simply select the clipped item and assign a stroke,
2. If you have used multiple maps and clips and want the whole area to have a border select all clipped items, turn off and stroke and then trace around the whole perimeter, assign a stroke with no fill. These can then all be grouped – again DO NOT try to clip multiple copies of the map – you have been warned!
CREATING A SCRAPBOOK LIBRARY OF HATCHING
1. Open a new LO doc,
2. Drag in all your hatch patterns and arrange as suits,
3. Save doc as scrapbook – name file as wished!
HOPE THIS HELPS!
Richard
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Re: TUT: Creating and Hatching in LayOut
Postby OTB Designworks » Thu Jan 06, 2011 3:03 pm
Thanks Richard! This tutorial is excellent and much appreciated.
Cheers, Chuck
MY BLOG
Become a fan of OTB Designworks on Facebook, we'd love to have you!
3.2ghz 8 core Mac Pro. 10 gig RAM, 8800 GT GPU, dual monitors
OTB Designworks
Postby utiler » Fri Jan 07, 2011 2:22 am
Me too, Richard. nice work around...! :thumb:
utiler
Top SketchUcator
SketchUp version: 8
License type: Pro
Postby Richard » Fri Jan 07, 2011 11:45 pm
You welcome mate! The beauty of LO is it produces GREAT clean exports in both image formats and PDF so it's own exports make for very suitable content when bought back in!
Did I say I love layout!
Richard
SketchUp version: 8
License type: Pro
Postby OTB Designworks » Sat Jan 08, 2011 3:31 pm
I am a big fan of LO as well; I am glad that Google has continued development.
Cheers, Chuck
MY BLOG
OTB Designworks
Postby Richard » Sun Jan 09, 2011 11:44 pm
Mate if many or even a few of the many requests that I know Andrew and myself have been pushing for through beta as additional functions are ever included Layout will become a serious app. Mind you I think the Googies have their own plans and IMHO they are pretty cluey guys and gals - so although we put up ideas they tend to run with some pretty funky ways to incorporate such functionality.
For this reason I certain future builds will hold some VERY cool features!
Richard
SketchUp version: 8
License type: Pro
Postby utiler » Sun Jan 09, 2011 11:54 pm
Richard wrote: Googies
Sounds like something that 'hatches' from your nose.....
utiler
Top SketchUcator
SketchUp version: 8
License type: Pro
Postby Rich O Brien » Mon Jan 10, 2011 12:10 am
Googies are eggs here :roll:
:::Blog:::
I'm a Trimbler now!
Rich O Brien
Administrator
SketchUp version: 8
License type: Pro
SketchUp use: engineering and mechanical design
Postby utiler » Mon Jan 10, 2011 12:46 am
Rich O'Brien wrote:Googies are eggs here :roll:
same here, Rich; just depends how you say it.
Pronouncing double 'O' as in 'Good' gives you eggs.
Pronouncing double 'O' as in 'Google' gives you; well, nose stuff.
utiler
Top SketchUcator
SketchUp version: 8
License type: Pro
Postby Edson » Wed Jan 12, 2011 3:10 pm
thanks, richard! much appreciated. :thumb:
edson mahfuz, architect
http://www.mahfuz.arq.br
Anyone can get you more for more, but it takes genius to get you more for less.
Edson
Global Moderator
Operating system: Mac
SketchUp version: 8
License type: Pro
Postby ladcwei » Fri Jan 14, 2011 7:29 am
If we can fill sections of su model easily,that's must be a nice day.Sections are always complex,so we cann't draw alone them with pencil tool in LO.Hope that day coming soon......
ladcwei
Postby kalu » Fri Jan 21, 2011 4:59 pm
Excellent work Richard, thank you for your work.
Kalu.
PS. I will put my hands on it!
THE ONLY DIFFERENCE BETWEEN FICTION AND REALITY IS WHEN FICTION HAS TO BE CREDIBLE
kalu
SketchUp version: 8
License type: Pro
Postby alexdi » Tue Apr 12, 2011 7:30 am
Спасибо Richard ! :thumb:
alexdi
Postby pedrinalex » Sun Apr 21, 2013 7:53 pm
Thank you Richard:
regards
Pedro
MB ASUS M5A97 EVO, AMD FX8120, 32 GB RAM Vengance 1600, 2 Sapphire HD 7770, Crossfire, 4 HD 1 TB c/u
pedrinalex
SketchUp version: 8
License type: Free
Need Authorised SketchUp Training by experts in various disciplines? Check out our Training details.
Return to LayOut Discussions
