Un-equal behavior between two identical instances
the same exact plugin/extension/ruby files exist in each of my machines running pro 2016 with the same version 16.1.144 64 bit. however, machine A only lists the curve maker extension; machine B properly lists all the plugins. what am i doing wrong?
ANSWER - NOTHING. i had to reinstall the program - and then it worked fine.
Edit your Title and write Resolved!
