SketchUcation Plugin Store
webdialogs: inputbox shows black background (sketchup webkit
Postby jeroentheuns » Wed May 16, 2012 9:14 pm
webdialogs: inputbox shows black background (sketchup webkit osx)
Following html inputbox shows with a black background color when loaded inside a sketchup webdialog. Same html file opens ok on safari.
Until 2 days ago it worked ok in sketchup. I DID UPGRADE TO LION 10.7.4
restarting SketchUp and computer doesn't help
removing all other plugins and restarting Sketchup doesn't help
removing all sketchup preferences (plist files in library/preferences/) doesn't help
removing and reïnstalling sketchup doesn't help.
Does anybody know where sketchups webkit stores it's cache? In 'com.google.sketchuppro8.plist'I see
<key>WebKitCacheModelPreferenceKey</key>
<integer>1</integer>
I was thinking to set this to 0 as to force webkit/sketchup to clean it's cache as I suspect there is something in there that gets loaded and produces this incorrect html rendering.
I can see this by opening the file in textwrangler, but textwrangler apparently cannot correctly save the editet binary format.
SketchUp 8.0.11751, OSX Lion 10.7.4
jeroentheuns
Re: webdialogs: inputbox shows black background (sketchup we
Postby driven » Wed May 16, 2012 10:51 pm
hi if you have Apples Developer Tools you can use Web Inspector to find the cause...
see this post http://forums.sketchucation.com/viewtopic.php?f=180&t=37277&p=328917&hilit=enable+webInspector#p328855
john
driven
Top SketchUcator
Operating system: Mac
SketchUp version: 2013
License type: Pro
SketchUp use: engineering and mechanical design
DC components dimensions blacked out
Postby mwm5053 » Mon May 21, 2012 1:06 am
Well by the subject you can tell my problem. It seems to be native to my computer. Mac OSX 10.7 using SU 8 Pro the same DC comp. on my WIN laptop are correctly displayed. The peculiar thing is the DC comp. from Google are able to change dim.
mwm5053
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
SketchUp use: hobby
Postby mwm5053 » Mon May 21, 2012 1:03 pm
John, I saw the link you posted and that's way over my expertise. In the skp file I uploaded the DC components values were blacked out all but the ones from Google any reason why? The components from Sketchdata and Kraftmaid still had some options that however were still accesable ;)
mwm5053
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
SketchUp use: hobby
Postby petersaal » Mon May 21, 2012 5:01 pm
I found the same problem last week. The source of the problem is the Safari update that Apple pushed out last week (5.1.7). Here's a work-around for dynamic components: make the following edits in red to the manager.css and configurator.css files. (located in Library/Application Support/Google SketchUp 8/SketchUp/Tools/Dynamic Components/css)
In Manager.css:
.edit-field {
position: absolute;
border-top: 2px solid #3063C9;
border-left: 2px solid #3063C9;
border-right: 2px solid #A5C4FF;
border-bottom: 2px solid #A5C4FF;
background-color: white; font-size: 12px;
font-family: sans-serif;
width: 100%;
height: 100%;
overflow: hidden;
padding-left: 2px;
padding-top: 1px;
border: 1px solid #000000;
In Configurator.css:
.config-field {
width: 100%;
font-size: 11px;
font-family: tahoma, sans-serif;
height: 22px;
.config-field-readonly {
width: 100%;
font-size: 11px;
height: 22px;
background-color: threedface;
petersaal
Postby petersaal » Mon May 21, 2012 5:26 pm
Just in case I wasn't clear in the previous post, you only need to make the additions/changes in red.
Here's some background on the issue on StackOverflow:
http://stackoverflow.com/questions/1058 ... oa-webview
petersaal
Postby rdeath » Mon May 21, 2012 11:22 pm
Hi, i have located the manager.css and configurator.css files and opened them. I don't seem to be able to edit them. Can you point me in the right direction. THX for finding the problem it's been driving me nuts. Look forward to your help
rdeath
Postby Gaieus » Mon May 21, 2012 11:26 pm
rdeath wrote:I don't seem to be able to edit them.
Why not? Open it in a plain text editor (not a word processor) and you can simply copy/paste those lines then save.
Administrator
Operating system: Windows
License type: Pro
SketchUp use: historical reconstruction
Level of SketchUp: Advanced
Postby rdeath » Tue May 22, 2012 12:19 am
Ok, I have done all that RESTARTED iMAC and things don't seem to have changed.....? Any ideas..?
rdeath
Postby mwm5053 » Tue May 22, 2012 12:39 am
@ Petersall
I followed your suggestion and didn't seem to make any differance :(
Did I do it right?
Edit Went back and corrected a few errors and fine now.
mwm5053
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
SketchUp use: hobby
Postby Dan Rathbun » Tue May 22, 2012 7:44 pm
rdeath wrote:Ok, I have done all that RESTARTED iMAC and things don't seem to have changed.....? Any ideas..?
Clear your browser cache (or temporary internet files directory.)
Dan Rathbun
Top SketchUcator
License type: Pro
SketchUp use: education
Postby mwm5053 » Tue May 22, 2012 9:02 pm
Still no luck
mwm5053
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
SketchUp use: hobby
Re: DC components dimensions blacked out
Postby Jeff Hammond » Wed May 23, 2012 3:05 am
mwm5053 wrote:Well by the subject you can tell my problem. It seems to be native to my computer. Mac OSX 10.7 using SU 8 Pro the same DC comp. on my WIN laptop are correctly displayed. The peculiar thing is the DC comp. from Google are able to change dim.
that's odd.. (i'm seeing the same behavior..)
the items are still editable, it's just that the black is the same color as the text so you can see it.. if you triple click an entry, the field will highlight in blue so you can see it.. (when blue, push delete then enter your new numbers ..albeit blindly)
heres a shot after focusing the component options dialog then selectAll-- :? :?
dotdotdot
Jeff Hammond
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Postby Aerilius » Wed May 23, 2012 11:33 am
Your image shows a website (that is loaded from the internet and can't use these css hacks). Does it at least work for components options?
mwm5053 wrote:Still no luck
Can you check again that all the css properties are separated with a semi-colon? I think you forgot one in .config_field.
Another idea, would a WebView also accept a user stylesheet (that would override the default background in all websites+webdialogs in SketchUp)?
Aerilius
Top SketchUcator
Postby mwm5053 » Thu May 24, 2012 12:51 pm
I saw that and thanks for pointing that out but still seeing black fields. Jeff's solution did allow me to change width dimension ultimately. I don't think this a SU thing however I believe it was an update to the Safai browser for Macs after the Flashback incident. From what I've read it not only effected SU but other programs that use webdialog boxes on Mac. Emptying the cache hasn't proved to be useful either.
mwm5053
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
SketchUp use: hobby
Postby rdeath » Thu May 24, 2012 2:10 pm
OK, purged cache in Safari and still no luck...!! anything else i can try..??? this is VERY frustrating..!!
rdeath
Postby petersaal » Fri May 25, 2012 7:54 pm
Move "font-size: 12px;" down to its own line. I had that on the same line as background-color and that's an error on my part.
If that doesn't do the trick, the only difference might be the OS X version. I'm still on 10.6 and I don't have a way to test 10.7.
Just to be clear: this fix is only for dynamic components. It will not fix the 3D Warehouse search box or any other affected software on the mac.
petersaal
Postby lwerner » Sat May 26, 2012 6:52 am
Thanks for posting this workaround! It worked perfectly for me. (On OSX 10.7.4 Lion, Sketchup 8.0.14345 Pro)
Laura
lwerner
Postby Juantxo » Tue May 29, 2012 9:30 pm
When I updated to Safari to 5.1.7 in Mac Leopard webdialogs boxes turn black in Sketchup.
I've installed an older version of safari with pacifist and now it works again.
http://www.charlessoft.com/ (pacifist software)
http://mac.oldapps.com/safari.php (Safari 5.1.1 (Snow Leopard))
Juantxo
SketchUp version: 8
License type: Pro
Postby Jeff Hammond » Tue May 29, 2012 11:39 pm
lwerner wrote:Thanks for posting this workaround! It worked perfectly for me. (On OSX 10.7.4 Lion, Sketchup 8.0.14345 Pro)
Laura
ditto.. works fine for me too..
thanks peter.
dotdotdot
Jeff Hammond
Global Moderator
SketchUp version: 8
License type: Pro
Postby TeamSDA » Thu May 31, 2012 7:19 pm
Hi All,
The fix Peter provided worked for the fields in my DC options window. But when I open my custom attributes window and look at the "Display Label" it is black as well. I couldn't find the style in the css style sheet that changed this input field. Does anyone know the style I need to change.
(On OSX 10.6.8 Snow Leopard, Sketchup 8.0.14345 Pro)
Regards,
Christian
TeamSDA
Postby mwm5053 » Mon Jun 25, 2012 6:10 am
Juantxo wrote:When I updated to Safari to 5.1.7 in Mac Leopard webdialogs boxes turn black in Sketchup.
Update If you find more black dialoge boxes blacked out like in profile builder or at 3d warehose this solution of Juantxo will work for all blacked
out dialoge boxes follow instructions on this page to revert Safari back to 5.1.1 even though it's for a earlier ver.
http://appletoolbox.com/2010/06/downgra ... ari-4-0-5/
mwm5053
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
SketchUp use: hobby
Postby Jeff Hammond » Mon Jun 25, 2012 4:09 pm
fwiw, i did the DC fix a while ago and yes, it works but as mentioned in this thread, it only works with the DC dialog.. skindigo was also exhibiting this blacked out behavior so i eventually downgraded safari using the method mentioned by Juantxo a few posts back.. pacifist with an older version of safari..
and that fixes everything in sketchup instead of just the DC dialog.
dotdotdot
Jeff Hammond
Global Moderator
SketchUp version: 8
License type: Pro
Postby mwm5053 » Mon Jun 25, 2012 8:18 pm
I wonder if this has been reported to apple so the next Safari update will resolve this? BTW Still love my MAC
mwm5053
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
SketchUp use: hobby
Postby driven » Mon Jun 25, 2012 10:03 pm
I'm using the developer release of Safari 6 and the problem remains in SU.
Safari's User Agent Style Sheet, handles the input border correctly but SU doesn't use that, so it's a WebCore update that's needed. i'm looking for a patch at the moment.
john
driven
Top SketchUcator
License type: Pro
Postby mwm5053 » Mon Jun 25, 2012 10:07 pm
Thanks John I'd like to stay updated on this as I like to stay updated on all software.
mwm5053
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
SketchUp use: hobby
Postby GOHCH » Thu Jun 28, 2012 1:33 am
Thanks guys!
I managed to get all the dialog boxes of 1001bit fixed following the suggestions on the css;
It's a lot of work to edit all the html files, but at least the problem is solved. :D
Cheers!
GOHCH
Name: Goh Chun Hee
Postby RichMorin » Tue Jul 03, 2012 1:52 am
I grabbed a copy of Pacifist, but I can't find a copy of Safari 5.1.5 to install.
For example, the page http://support.apple.com/kb/DL1070
has a Download button that leads to http://www.apple.com/safari/download/.
However, this page only supports downloading of Safari 5.1.7.
Help?
RichMorin
SketchUp version: 8
License type: Pro
SketchUp use: interior design
Level of SketchUp: Beginner
Postby troypiggo » Tue Jul 03, 2012 2:03 am
This is not my signature. I type it at the end of every message for quality control.
troypiggo
Postby driven » Tue Jul 03, 2012 3:02 am
update to my investigation.
WebView uses a different version of Webkit than Safari (and not just in SU) and I can't find a way to change the userAgent from within SU, so been trying another approach.
Code: Select all
dlg.execute_script %(function addGlobalStyle(css) {
   var head, style;
   head = document.getElementsByTagName('head')[0];
   if (!head) { return; }
   style = document.createElement('style');
   style.type = 'text/css';
   style.innerHTML = css;
   head.appendChild(style);
addGlobalStyle('input {border: 1px solid gray;}'))
This works if you know the name of the dialog, but how can I get that with ruby to apply a global patch. Is it possible to get a new dialog name in ruby.
Using WebInspector to add the JS I can also exclude type with
Code: Select all
addGlobalStyle('input, input:not[type="submit"]:not[type="button"]:not[type="file"]:not[type="search"]{border: 1px solid gray;}'))
, but that returns true and fails in RubyConsole
john
driven
Top SketchUcator
License type: Pro
Need SketchUp Books, Models, Styles or Textures? Check out our One Stop Shop for SketchUp.
Next
Return to SketchUp Bugs
