Exporting 2D graphic in dwg > doesn't create the file
Found a bug in SketchUp? Report it here
Postby mdg44 » Tue Jan 17, 2017 7:05 pm
Hi all,
When trying to export a 2D graphic, using file > export > 2d graphic and choosing dwg file format and the location, Sketchup acts like it does when exporting to any other file format but when I go to the folder, the file isn't actually there.
I can export to pdf to that same folder, but when doing so to dwg the file doesn't appear.
I am using Sketchup Pro 2017 on a Macbook pro with OSX 10.11.6 installed. The same thing used to happen back when I was using Sketchup Pro 2015. Both are licensed versions.
mdg44
Re: Exporting 2D graphic in dwg > doesn't create the file
Postby John Sayers » Wed Feb 01, 2017 1:16 am
works for me in windows version
User avatar
John Sayers
Postby slbaumgartner » Wed Feb 01, 2017 7:55 pm
It works for me on mid-2012 MBP retina, SU 2017, OS X 10.12.3.
slbaumgartner
PluginStore Author
PluginStore Author
Postby TIG » Wed Feb 01, 2017 8:43 pm
Since we don't have your specific SKP file...
Does it contain some geometry - lines/faces etc - which could get exported into a DWG ?
Could you attach a simple SKP example that fails to make a DWG etc...
User avatar
Global Moderator
Postby JQL » Wed Feb 01, 2017 9:19 pm
Or are you trying to export a section without an active section in the model
User avatar
JQL
Premium Member
Premium Member
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to SketchUp Bug Reporting
Who is online
Users browsing this forum: Google Bot and 1 guest
Visit our sponsors:
