SketchUcation Plugin Store
Lock toolbars
Re: Lock toolbars
Postby Jim » Wed Dec 08, 2010 3:00 pm
I have taken to not using Toolbars, or having a very minimal number open. I wrote a custom WebDialog (or 2) to replace Toolbars. One dialog is a general toolbar replacement, the other toggles the normal Toolbars visible/not visible. The dialogs are pretty rough around the edges since I am the only one who uses them; but they do show what can be done and how the WebDialogs can (and will) be an effective alternative to the built-in Toolbars.
There are a few other, similar plugins that are using webdialogs as toolbar alternatives.
My dialogs: the short texts are buttons, too.
(moved post from another topic)
Jim
Global Moderator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: other
Re: Lock toolbars
Postby rockstarkid76 » Tue May 24, 2011 6:42 am
remus wrote:Julian, why dont you get rid of all your toolbars and jsut use keyboard shortcuts? it takes a bit of getting used to but its a lot faster :geek:
BUT NOT ALL COMMANDS HAVE SHORTCUTS!
rockstarkid76
Name: rocky mapanirya
Re: Lock toolbars
Postby rockstarkid76 » Tue May 24, 2011 6:44 am
a4chitect wrote:there is a little trick to help you, once you are happy with your toolbar arrangement, close sketchup (the UI gets saved internally). anytime your screen gets resized, or messed up, or your toolbars change - don't close sketchup, open another instance of sketchup - this one opens with the original UI. then close both windows but make sure that you close the clean and tidy @last :D
this way your clean UI gets saved as last overwriting the messy one (since all instances of sketchup share one UI setting)
GREAT!!! THANKS
rockstarkid76
Re: Lock toolbars
Postby thomthom » Tue May 24, 2011 8:16 am
You can set up your own shortcuts from Window > Preferences > Shortcuts
(p.s. Please don't use all caps when writing a post. It's considered bad forum manner. If anything, use all lower. Makes things much easier to read and it doesn't make you look like you are yelling.)
Global Moderator
Name: Thomas Thomassen
SketchUp version: 2013
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Re: Lock toolbars
Postby rockstarkid76 » Tue May 24, 2011 8:26 am
im sorry for using all caps.my apologies :oops:
rockstarkid76
Re: Lock toolbars
Postby numerobis » Wed Mar 28, 2012 6:35 pm
sorry... but every time i read this topic title i have to laugh... it's really a big joke that this annoying little problem is still not fixed after such a long time!
If this is such a hard thing to do, the developers of nearly all other softwares i know must be real geniuses since they found a solution for this "unsolvable" problem... :roll:
numerobis
SketchUp version: 8
License type: Pro
Re: Lock toolbars
Postby Tobobo » Sat Mar 31, 2012 10:08 am
numerobis wrote:sorry... but every time i read this topic title i have to laugh... it's really a big joke that this annoying little problem is still not fixed after such a long time!
the save tool bars have gone along way to solve it. Though saying that it hasn't happened in a while. touch wood
Toby
Philippians 4:13
http://tobyjoyce.wix.com/home
Tobobo
SketchUp version: 8
License type: Pro
SketchUp use: landscape architecture
Re: Lock toolbars
Postby kwistenbiebel » Mon Apr 02, 2012 4:16 am
Yes, annoying bug still around.. :)
kwistenbiebel
Re: Lock toolbars
Postby findthong » Sat May 05, 2012 12:28 pm
Jim wrote:I have taken to not using Toolbars, or having a very minimal number open. I wrote a custom WebDialog (or 2) to replace Toolbars. One dialog is a general toolbar replacement, the other toggles the normal Toolbars visible/not visible. The dialogs are pretty rough around the edges since I am the only one who uses them; but they do show what can be done and how the WebDialogs can (and will) be an effective alternative to the built-in Toolbars.
This is quite nice. Everyone here having some problem with Toolbar, but my problem is Web Dialogs LOL.
I'm using Dual monitor set up. Sometime I work with SketchUp on my 1st monitor when SketchUp is being my top priority and many time I've to move it to 2nd monitor. And web dialogs not going to move with SketchUp. That's quite annoying and I need to do a lot workaround and get familier with it.
And I've just counted I've 112 shortcut combinations to get aroud these UI problem as much as possible! And I can remember 80 percent of them, but not much icons!. It need a lot brain power, when you want to have less moving around as possible while using a lot of scripts to prevent tedious tasks as much as possible. I can't imagine I can even work in SketchUp without my cheat sheet or on other computer :D.
We definitely need some UI love for extensive users, because there're so many advanced SketchUp user around!
findthong
Re: Lock toolbars
Postby shawnkelly » Sun Feb 24, 2013 7:28 pm
Sounds like some of the users in this post need to move to another software. This is called Sketch-Up for a reason. I was most likely developed by someone that was tired of the limitations of pencil and paper. It is meant for sketching out ideas quickly without the fuss of all that you people bring to it. I despise the other programs because of their complexity. I use them (Rhino and Modo) of course because they are unnecessary but not at the beginning of a project that has no initial parameters. Do not try to make it so hard on yourselves, it steals all the fun out of it.
BTW, has anyone tried View>Toolbar>Save Toolbar Location/Restore Toolbar Location. I crash (Bug-Splat) Sketch-Up all the time and I have yet to manually move all my toolbars back to their positions after restoring them.
shawnkelly
Re: Lock toolbars
Postby Rich O Brien » Sun Feb 24, 2013 8:16 pm
No splat here on Restore Toolbars
:::Blog:::
I'm a Trimbler now!
Rich O Brien
Administrator
SketchUp version: 8
License type: Pro
SketchUp use: engineering and mechanical design
Re: Lock toolbars
Postby pbacot » Sun Feb 24, 2013 8:48 pm
We don't have this problem on Macs.
The toolbars are never in a good place, never where you put them, same with windows so they can't be messed up. You get the Mac "customize toolbar" which also sucks.
Top SketchUcator
Operating system: Mac
SketchUp version: 8
License type: Pro
Re: Lock toolbars
Postby MichaelNeyses » Sun Apr 21, 2013 6:01 pm
I just cant fathom, what you guys are doing with your toolbars, I closely watched the progress of this discussion. I almost feel guilty by not having this genuine problem at all.
If the bars are disturbed, which very rarely occurs, I hit the ALT/F9 Button that I have set on the 'Restore Toolbars' command and all the boys are back in place.
I dont have any explanation for this good behavoir other then maybe that I am using a 30" screen which gives me planty of room not to mess in the vicinity of the bars.
I rely very much on SU during my workday and produce at least 50 projekts a year. I would have never stuck with this software, if there were such instances as the need of rearranging the landscape of toolbars 5 times a day! Maybe choose the plugins I am using a bit carefully but I have learned long ago that being a gearhead and jumping on any train is the least splendid of all forthcoming methods.
MichaelNeyses
SketchUp version: 8
License type: Pro
Re: Lock toolbars
Postby Gaieus » Sun Apr 21, 2013 8:59 pm
Note that this discussion started in 2008 (see first post) when there was no such function as "Save toolbar position" or "Restore toolbar position".
People keep re-discovering this topic time-to-time...
Administrator
License type: Pro
SketchUp use: historical reconstruction
Re: Lock toolbars
Postby panixia » Sat Apr 27, 2013 10:57 am
MichaelNeyses wrote:I dont have any explanation for this good behavoir other then maybe that I am using a 30" screen which gives me planty of room not to mess in the vicinity of the bars.
of course not, the width of the monitor doesn't matter. the pixel count does.
if you got a 17" 1920x1280px and a 40"1920x1280 px you got the same "pixel space" to use with your toolbar buttons (wich have a fixed pixel dimension).
the only difference is that you see bigger pixel, so that you can actually visualize bigger buttons, but you can dock the same amount of buttons than the smaller monitor does.
i find that in order to visualize more toolbars/dialogs and other UI elements it's a more effective solution to use 2 smaller monitor rather than 1 bigger montitor.
(or maybe 2 bigger montor if you got the cash for it of course)
panixia
SketchUp version: 8
License type: Free/Make
SketchUp use: other
Vertex Tools for SketchUp. Take control over each vertex with this vertex editor for SketchUp.
Previous
Return to SketchUp Wishes
Users browsing this forum: No registered users and 6 guests
