Scaling/grouping changes
Got an idea to improve SketchUp?
Postby remus » Thu Mar 20, 2008 11:42 pm
Not sure how difficult/easy this would be to implement, but itd be really cool if SU could create the bounding box for a group based on its dimensions rather than its orientation to the axis.
As an example, if you draw a rectangle then rotate it by 30 degrees. If yu then group this the bounding box is aligned to the axis which makes everything (including scaling) a lot more annoying. What im trying to say is, would it be possible to make the bounding box line up with the rectangle?
remus
Re: Scaling/grouping changes
Postby lewiswadsworth » Fri Mar 21, 2008 5:08 am
You know, you can fix that, if you quickly convert that group to a component(which is just a right-click)...just right-click (again!) on the new component and choose "Change Axes" from the context menu. Align the new axes to the bounding box edges that you want and you're set.
I actually like things the way they are, so that I can change the orientation of the bounding box without affecting the component contents, but then I'm a little odd about the way I use SketchUp.
lewiswadsworth
Postby remus » Fri Mar 21, 2008 9:19 am
Cheers for the tip lewis, but its still a workaround ;)
remus
Postby plot-paris » Tue Apr 01, 2008 2:09 pm
I would be totally happy, if the bounding boxes of groups would allign to the actual axes.
if you change your axes (for example to fit a house into an existing survey model and still be able to refer to the house's axes), SketchUp still alignes the bounding boxes of new groups to the original axes.
that can drive you mad (and made me cheat with the compass orientation instead of rotating the building to its correct orientation).
but your idea sounds interesting too.
User avatar
plot-paris
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to SketchUp Feature Requests
Who is online
Visit our sponsors:
