Grid on Ground
Got an idea to improve SketchUp?
Grid on Ground
Postby SpaceMan » Thu Feb 14, 2008 2:47 am
Can you make a grid on the ground? and the grid can be a point of color-coded feedback. The size of square is depend on the unit of the model. Unlike Ruby script 3D Grid, the grid is infinity-extended.
SpaceMan
Re: Grid on Ground
Postby Baker518 » Thu Feb 14, 2008 3:14 am
If I recall, there are at least 3 different grids I have seen and it seems like they are size-able from a pop-up when you select them.
Don't worry about things you have no control over. Worry is a lack of Faith!
Baker518
Re: Grid on Ground
Postby Edson » Thu Feb 14, 2008 11:10 am
int tools menu, choose grid
then define the origin, grid spacing and number of units in both directions.
edson mahfuz, architect | porto alegre • brasil
http://www.mahfuz.arq.br
Edson
Global Moderator
Re: Grid on Ground
Postby Jim » Thu Feb 14, 2008 11:30 am
Hi Edson,
You must have a "grid" plugin installed.
Jim
Global Moderator
Re: Grid on Ground
Postby Edson » Thu Feb 14, 2008 11:52 am
yes, it is here for anyone to download. it is a free script called parametric grid.
Edson
Global Moderator
Re: Grid on Ground
Postby Gaieus » Thu Feb 14, 2008 11:53 am
Yes, there is one (lthough not like an infinite plane.
I like it because when we dig at excavations, we usually work in 10m X 10m grids and when I get back to SU I can easily navigate within my model.
Re: Grid on Ground
Postby SpaceMan » Thu Feb 14, 2008 8:48 pm
So it's not infinte plane...
SpaceMan
Re: Grid on Ground
Postby gata » Fri Feb 15, 2008 12:38 am
The parametric grid script, like it's name implies, is parametric - infinitely editable. Select grid, r-click and Choose Edit Grid. From there you control the size of the grid and the individual grid increments.
gata
Re: Grid on Ground
Postby alz » Wed Mar 26, 2008 4:49 am
The ideal grid:
- it can be scaled by a hotkey which doubles in size
- it is infinite (no need to set distance points)
- it isn't an actual object in the Outliner
- it has line weighting (ie. every 4th or 8th line is darker/heavier)
- it adjusts its visual screen draw to prevent moiré patterns
- if in an orthogonal view, it covers the background (ie. front, top, right)
- it is tied into the snap distance and unit of measurement
Thoughts?
alz
PluginStore Author
PluginStore Author
Return to SketchUp Feature Requests
