Herramientas,
Got an idea to improve SketchUp?
Herramientas,
Postby Manoli Garcia » Thu Jun 11, 2015 2:57 pm
Hecho de menos en Sketchup.
Poder usas grosor de lineas.
Poder usas tipos de lineas.
Poder usas color de lineas.
Poder unir lineas.
Poder alargar lineas.
Poder acotar grados.
Manoli Garcia
Re: Herramientas,
Postby cotty » Thu Jun 11, 2015 6:02 pm
google translation:
Code: Select all
I miss in Sketchup.
Power using thick lines.
Power lines use types.
Power lines use color.
Uniting power lines.
Power lines lengthen.
Power limit degrees.
I don't understand this.
I don't see the question.
I...
User avatar
cotty
Top SketchUcator
Re: Herramientas,
Postby JQL » Thu Jun 11, 2015 6:52 pm
Google translate is funny! But you're right Cotty, there is no question there, only statements! :P
I'm a Portuguese but I'd translate this from what's written in Spanish:
"Poorly developed stuff in Sketchup.
Being able to use line thickness.
Being able to use line types.
Behing able to use line colors.
Being able to join lines.
Being able to stretch lines.
behing able to dimension angles."
I'd respond like this:
"Sketchup é bem desenvolvido.
Poder fazer modelos.
Poder apresentá-los.
Poder exportá-los.
Poder integrar plugins para os potenciar."
User avatar
JQL
Premium Member
Premium Member
Re: Herramientas,
Postby TIG » Fri Jun 12, 2015 9:48 pm
So...
Use Layout - or Plugins like 2dTools-LineStyle
Being able to use line colors.
Use Layout - or Plugins like 2dTools-LineStyle - or Style Color-by-Material
Use Plugins that 'Weld' [e.g. TIG-Weld] or 'Merge' unneeded vertices [Fredo's toolset]
Use the native Move on a vertex, Entity Info to change Length etc
Being able to dimension angles.
Layout - or there are Plugins available...
User avatar
Global Moderator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to SketchUp Feature Requests
cron
Who is online
Visit our sponsors:
