Trim multiple objects against one object in one click
Got an idea to improve SketchUp?
Postby hugof » Wed Jan 14, 2015 4:23 pm
Hi, I would really appriceate a development of the boolean trim function so that you first click on cutting object and then can select several objects to trim at the same time and still keep them as separate groups/components after the trim. Absolute best would be if selecting the objects to be trimmed worked in a similar fashon as the ereaser, so you just click and erease the edges you want to trim away. Currently you have to click on one group/component at a time. This results in very much clicking which is very time consuming if you have hundreds of objects to trim in, for instance, a facade.
Seems like an easy thing to fix / make a plugin for!
hugof
Re: Trim multiple objects against one object in one click
Postby cotty » Wed Jan 14, 2015 6:10 pm
Have a look at "trim and keep" and "VisuHole" plugins.
cotty
Top SketchUcator
Postby gilles » Wed Jan 14, 2015 6:21 pm
gilles
Top SketchUcator
Postby cotty » Wed Jan 14, 2015 6:31 pm
This was my favorite for years and I am still using it too, but VisuHole don't need solids which is a great advantage... see this example screencast:
cotty
Top SketchUcator
Postby gilles » Wed Jan 14, 2015 6:43 pm
Missed this one.
gilles
Top SketchUcator
Postby cotty » Wed Jan 14, 2015 6:50 pm
gilles wrote:Missed this one.
You know the important rule "Don't miss a Fredo plugin!" ? ;)
cotty
Top SketchUcator
Postby cotty » Wed Jan 14, 2015 6:58 pm
And a quick "trim and keep" (PRO only) example...
cotty
Top SketchUcator
Postby Jean-Franco » Wed Jan 14, 2015 7:50 pm
and another important rule >>> Don't miss a cotty tutorial :D
Jean-Franco
Jean-Franco
Postby pilou » Wed Jan 14, 2015 9:57 pm
Yes Visuhole is a task! :fro:
Speedy Galerie
Top SketchUcator
Return to SketchUp Feature Requests
