SketchUp 2015 Wishlist
Got an idea to improve SketchUp?
Re: SketchUp 2015 Wishlist
Postby architeriffic » Fri Jul 18, 2014 4:53 pm
I would like to have the ability to create jogged section cuts. Just create a surface, make it a component, right click on it and turn it into a section cut.
architeriffic
Postby gudio83 » Thu Jul 24, 2014 12:28 pm
Cut / making hole through all complicated components (content many other components and groups)
gudio83
Postby mitcorb » Thu Jul 24, 2014 1:15 pm
@gudio83:
See this link: viewtopic.php?f=323&t=58335.
An extension or plugin like this is more likely to happen than it being incorporated into the program itself. Is this what you are describing in your comment?
mitcorb
Top SketchUcator
Postby TK0001 » Tue Jul 29, 2014 5:28 pm
I would like layer transparency and to have it save-able in Scene Manager, so you could "ghost out" non-essential information in a certain scene, and "highlight" the things you want to stand out. Essentially, creating a scene that looks like when you double-click on a group or component within a larger model.
TK0001
Premium Member
Premium Member
Postby manhaaa » Wed Jul 30, 2014 1:33 pm
Faster model manager with large file and material windows, entityinfo windows, Style Windows...working together in the one windows, maybe multi tab for them.
manhaaa
Postby pbacot » Wed Jul 30, 2014 7:38 pm
Better palette and dialog organization / control / consistency for Mac.
Top SketchUcator
Postby jonb42 » Wed Jul 30, 2014 9:36 pm
- Layout: Speed! I still find it too slow for complex models even using raster renders. I've often wondered sure why Layout can't use the same engine SU does while one is working with the layout, then do the heavy render processing only when it is time to export. We were told a 14x speed increase in the 2014 release but it sure doesn't seem that way to me!
- SU: Real circles, though not displayed as such for the sake of graphics speed - like Autocad which "knows" a circle is a circle in terms of snapping, dimensions, anything that matters; but only displays segments.
- Layout: fix the export to .dwg so that text stays where it is supposed to and in general the end product comes out looking like it did in layout. Understood Acad can't support some of the fancy graphics stuff Layout can, however what I find is titleblocks, text, dimensions moving around so much that the export is pretty unusable. I WANT to use Layout for all my sheet sets but because I have to submit .dwg copies I'm forced to do all my sheets and annotations in Autocad, xref-ing in the SU model.
- Ability to "fade" layers just like they seem to when you are editing a component / group but seeing the rest of the model. This is a great way to emphasize elements - lets say a run of pipe - through a cluttered background. This would need to be tied to scene generation just like whether a layer is on/off. It could be "fade all other groups/components" and / or "fade all other layers" for my money... And of course this functionality would follow through into layout.
- SU: enable dimension & leader text to have a background color so they stand out over geometry, like in layout.
- Stop the Esc key from quitting dialogs!!!!!!
- enable reverse mouse wheel zoom direction in the Mac version!
I think thats enough for a start :)
...And many thanks to the Sketchup team for a great product that has got so many things right already.
Jon
jonb42
Postby TK0001 » Wed Jul 30, 2014 9:42 pm
jonb42 wrote:- Ability to "fade" layers just like they seem to when you are editing a component / group but seeing the rest of the model. This is a great way to emphasize elements - lets say a run of pipe - through a cluttered background. This would need to be tied to scene generation just like whether a layer is on/off. It could be "fade all other groups/components" and / or "fade all other layers" for my money... And of course this functionality would follow through into layout.
TK0001 wrote:I would like layer transparency and to have it save-able in Scene Manager, so you could "ghost out" non-essential information in a certain scene, and "highlight" the things you want to stand out. Essentially, creating a scene that looks like when you double-click on a group or component within a larger model.
Great minds... :thumb:
3
TK0001
Premium Member
Premium Member
Postby bsfranza » Tue Aug 05, 2014 1:58 pm
flickerfree opacity/alphas ... when working with several alpha mapped trees and stuff things get ugly =)
would be awesome if this could somehow get fixed!!!
bsfranza
Postby torofacito » Mon Aug 11, 2014 10:20 pm
it would be good that door and window components cut to the wall precisely for a given thickness.
BIM plugins should be integrated in it
torofacito
Postby TANER TAN » Thu Oct 09, 2014 8:16 pm
Must be high resolution icons in the new version of Sketchup.
Hopefully, this time they do.
TANER TAN
Postby atelierpaar » Sun Oct 12, 2014 7:33 pm
My biggest SU - wishes are still :
[b]1. Speed
[b]2. true geometry of circles and curves
I understood - I am inside a box-program but I do not see the point not to progress.
It would make life so much easier to work with true circles/continues curves and to produce geometrical correct intersections.
2. STL-file export
After spending countless hours on a flawless SU 8-model, I learned from several 3d printing-shops, that the model could not be printed. :(
Apparently SU 8 produces a countless errors at the intersection of curved Volumes. :evil:
If The future really is 3d printing, its absolutely necessary to improve on curve-geometry and file-export :!: :!: .
atelierpaar
Postby erwinmeulman » Mon Oct 13, 2014 3:07 pm
Multi-threaded kernel COLLADA, as parasolid
erwinmeulman
Postby pbacot » Wed Oct 15, 2014 9:22 pm
A couple of things.
1. Give the control of visible toolbars to users. Many plugins are written to leave the toolbar in the workspace, when opening Sketchup, whether you had them open last session or not. That is you can't keep them closed.
2. Fix the extensions window in Preferences: So when you are tired of a set of toolbars opening up you go to the extensions window to turn the extension off. The extension window has a tiny scroll window that lists (some, not all) plugins. One must scroll up and down, searching for the right extension because THERE IS NO ORDER OR SEARCH FUNCTION. Make this list contain all plugins and make the window expandable, and please list alphanumerically like the rest of the world.
Top SketchUcator
Postby Box » Wed Oct 15, 2014 11:19 pm
1. I think you'll find that is an issue with the relevant plugins not SU.
2. Have you used the plugin and extension managers that are part of the Sketchucation plugin.
Postby pbacot » Thu Oct 16, 2014 12:06 am
Box wrote:1. I think you'll find that is an issue with the relevant plugins not SU.
1. So make it a SU issue. Why does Trimble leave the UI issues up to misc. plugin authors? SU has the worse UI setup of any app. I regularly use.
2. No. Sketchucation Store plugin? So you would use it to unload extensions that you have in the plugins folder?
Top SketchUcator
Postby utiler » Thu Oct 16, 2014 2:25 am
TANER TAN wrote:Must be high resolution icons in the new version of SketchUp.
Gee, you're easily pleased.....
utiler
Top SketchUcator
Postby Box » Thu Oct 16, 2014 9:59 am
Pbacot I'm not sure how Trimble can control a 3rd party plugin. Your original point was about plugins that are persistent on restart. This is because the code is written incorrectly causing the toolbar to open no matter what it's previous state was. So it's a fault in the plugin, not Sketchup. If you find a plugin that is doing it you should point it out to it's author.
As for Sketchucation tools, Yes you can turn plugins and extensions on and off, you can even create different set of plugins that you want to load together, you can uninstall plugins, update, auto install, load temporarily or permanently, you can use bundles to sync different computer so they have the same plugins, or create a specific bundle that you will only use on your laptop and auto load all of them with one click........I could go on and on but there are too many things it can do and more coming.
Postby pbacot » Thu Oct 16, 2014 4:43 pm
Thanks! I'll look at the SCF tools. However can't the developers of SU control/prohibit a particular action of a plugin? Isn't it the function of SU that allows the plugin toolbar to show in the first place?
And, of course, I think you realize, that although I can add managers and plugins to improve my use of SU (and I am glad of suggestions), it doesn't change a wish that the application were better out of the box, if only for the new user who doesn't have the plugins to solve their frustrations. I mostly find the extensions window a pain because it is SO poorly designed and is never improved, not that I haven't learned to live with it.
Top SketchUcator
Postby ArtPen » Thu Oct 23, 2014 1:03 pm
Have been working in sketchUP on a couple of complex architectural and landscape project just now and thought it will be worse to update a wish list.
GENERAL
1A. Xref or other proper Reference system with Project folder setup.
So you can see all References in the Master model and been able to open them start from the master model make changes in separate file,
then save and update the master model
1B. Some kind of team work please
2. X64 for big complex project
3. Texture folder. Each SketchUp file will have a separate Texture folder inside a project folder. To keep all organise.
4. Faster Viewport using modern OpenGL technologies. Nice representation , colours , anti-aliasing , soft shadows, nicer fog and light.
5. Groups for Layers
6. High Quality Google Maps with option to grab bigger locations
7. X64 and FASTER Layout
8. I think it is time to introduce wall, slab, window/door, curtain wall, elements
9. Components to be able to cut through walls ( two faces )
10. Better lines and curves. Able to see centre point of each curve. Able to see tangent points.
11. Line types (without using plugin)
OSX
1. Material list
2. Show total area of material in a model by right click on the material inside the material browser. Yo can do it on Windows
3. Better UI
4. Full screen
Just wanted to ask is there any official way to submit our wish lists to Trimble directly? Of cause they work hard to deliver better program but they quite close from the community.
Updates are very rear. No information is given unfortunately .
Cheers
ArtPen
Premium Member
Premium Member
Postby pbacot » Thu Oct 23, 2014 7:06 pm
ArtPen. Nice list.
On the XREF idea (it would be great if this were handled to save MB's), I have method that is similar, if you haven't tried it. I often use a component for a whole building, especially accessory buildings in site. I get the footprint laid out then I save the component (contextual menu) as SU file. I then do my work on the building in that file. I can "reload" (contextual menu) anytime into the main site file. It usually comes right in exactly where the old version was (occasionally I do something to throw it off, but it's easily fixed). You can make a file for the structure/ shell of the building that is used both in the site model, for exteriors, and in another model that has only interior elements for that building--so you are not compiling large models with useless geometry.
3
Top SketchUcator
Postby Anton_S » Fri Oct 24, 2014 7:12 am
Very nice list, ArtPen. It just summarizes everything that SU has to have.
Anton_S
PluginStore Author
PluginStore Author
Postby Krisidious » Fri Oct 24, 2014 5:05 pm
I want it all... and I want it now!
By: Kristoff Rand
Home Designer
Unique House Plans
Krisidious
Postby KrisM » Fri Oct 24, 2014 5:47 pm
"- Stop the Esc key from quitting dialogs!!!!!!"
Yes, yes, yes !!!!!!!!!!!!!!!
KrisM
Premium Member
Premium Member
Postby ArtPen » Fri Oct 24, 2014 10:46 pm
Pbacot thanks for the tip. I should try it.
Another though: Why not put SketchUP on App Store for Mac users?
ArtPen
Premium Member
Premium Member
Postby jeff hammond » Sat Oct 25, 2014 5:49 am
ArtPen wrote:Have been working in sketchUP on a couple of complex architectural and landscape project just now and thought it will be worse to update a wish list.
GENERAL
Cheers
good list artpen..
i disagree with #3 though.. i'd way rather have the textures stored in the .skp (as they are now).. otherwise, for every .skp i have, i'd also have a texture folder? sounds harder to organize.. not easier (for me at least)
#8.. hmm.. what are you imagining for that? a library of components? parametric components?
i'm not clear on what you're saying.
people from the sketchup team read these forums from time to time but they generally won't engage in a thread like this.
trimble has a discourse though:
http://forums.sketchup.com
there's a 'feature request' category available.
well, they do yearly updates these days so those long waiting periods seem to be over now.. but yeah, i don't think i can recall someone from the team saying "expect this in the next release" (or whatever).. that's just how they are.
dotdotdot
jeff hammond
Global Moderator
Postby driven » Sat Oct 25, 2014 12:51 pm
ArtPen wrote:Another though: Why not put SketchUP on App Store for Mac users?
1: it would need to be more expensive than the Windows version and negate all the approved resellers...
2: it may have to remove the ability to add Plugins, to comply with the App Store guidelines...
I don't think we want either of those.
john
driven
PluginStore Author
PluginStore Author
Postby ArtPen » Sun Oct 26, 2014 11:31 pm
Sketchup curtain walls. Check this out:
http://pingpinkstudio.weebly.com/about.html
ArtPen
Premium Member
Premium Member
Postby jeff hammond » Mon Oct 27, 2014 5:27 am
derei wrote:I WISH...
Arcs with variable number of segments (sides). Option to either set number of segments for arc (eg. 12), or to set the length of one segment and the total number of segments to be approximated depending on total length of the arc.
It also could be a nice plugin... I tried a piece of code, but I could not figure out how to make the inference, so I gave up.
you can sorta do this already
• draw arc
• right-click arc -> Divide
• move cursor around arc.. notice the pop up displays segment length and # of segments
--- (optional steps -- the above draws the correct geometry but destroys the su arc_ness)
• note the number of segments needed for the desired length
• esc out of the divide command
• right-click arc -> Entity info
• enter the correct number of segments
dotdotdot
jeff hammond
Global Moderator
Postby JQL » Mon Oct 27, 2014 5:59 pm
ArtPen wrote:...
1. Take a look at Inteloide's component manager plugin. Does that exactly;
3. There is a plugin that sort of does that too.
5. Jiminy's Layer Panel Plugin
8. Sketchup 2014 Classifier (IFC 2x3) predifineable does that already. Then you can do an IFC export.
http://www.sketchup.com/products/sketch ... perability
10. Even if I'm sure this is less than you ask for... there is a plugin for finding center points on exploded arcs and circles (the others you can already) there is also a plugin for true tangents and perpendiculars to arcs and circles.
JQL
Premium Member
Premium Member
PreviousNext
Return to SketchUp Feature Requests
