SketchUcation Premium Membership
BIM SKETCHUP
Re: BIM SKETCHUP
Postby bomastudio » Fri Apr 29, 2011 7:02 pm
Hi, I'm tryng ( :?: ) to make SketchUp a bit BIM-software....look at TECLA, and see if it can help you.....bye... :D
bomastudio
Operating system: Linux
SketchUp version: 8
License type: Free/Make
SketchUp use: architecture
Level of SketchUp: Advanced
Re: BIM SKETCHUP
Postby Jeff Hammond » Fri Apr 29, 2011 7:04 pm
bomastudio wrote:Hi, I'm tryng ( :?: ) to make SketchUp a bit BIM-software....look at TECLA, and see if it can help you.....bye... :D
boma - we're way too lazy for that! we need links :D
especially when:
Tecla
About 13,200,000 results (0.09 seconds)
dotdotdot
Jeff Hammond
Global Moderator
Operating system: Mac
SketchUp version: 8
License type: Pro
Re: BIM SKETCHUP
Postby pbacot » Fri Apr 29, 2011 9:49 pm
Top SketchUcator
SketchUp version: 8
License type: Pro
Re: BIM SKETCHUP
Postby ZFRPS » Sun May 15, 2011 8:47 am
+1
su---BIM
NICE!
sketchup is bim
ZFRPS
Re: BIM SKETCHUP
Postby d_e_x » Fri Dec 09, 2011 5:55 pm
Hi All,
My friends and I have created a building modeling plug-in for SketchUp. We have utilized our knowledge of popular BIM products (like REVIT) and tried to follow similar methodology and process-flows. This plug-in provides simple tools to create grids, floors, and all common structural engineering and architectural primitives like walls, columns, beams, slabs and openings.
and yes, it works on both Mac and Windows :) check it out here: viewtopic.php?f=323&t=41840
best!
Dex
d_e_x
Re: BIM SKETCHUP
Postby fionmacool » Wed Mar 21, 2012 12:10 pm
IFC ALERT: The UK is now.hosting an official gov. database for BIM components. If anyone wants to see SU as a serious player in the BIM market, and if it is possible to produce IFC compatible SU components this is our chance
http://www.nationalbimlibrary.com/
Any thoughts?
Zere are still some architectes zat do not know ow to use ze SketchUp..... Zis is unbelievable....
fionmacool
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
Re: BIM SKETCHUP
Postby ArCAD-UK » Fri Mar 23, 2012 12:30 pm
fionmacool wrote:Any thoughts?
If the objective is a basic library of industry standard (parametric) parts then great but if the objects are an attempt to duplication or replace parts of the specification then I fail to see a real benefit to the design process and the BIM data would best be ignored. The main purpose of drawings are to define the size, shape, location and assembly of the building parts. A complex BIM object will never correctly replace a properly written specification which would be a simpler and more reliable source of building information. They will never compete with the simple process of labelling a door [D-01] which can then be looked up in the specification with as much or as little information as necessary to define the product, quality of work, performance requirements and conditions under which the work is to be executed.
ArCAD-UK
Keyframe Animation plugin - animate your SketchUp model by adding movement to any object.
Return to SketchUp Wishes
